35's on Steelies
You’re cool man! seriously I always enjoy your posts they make me smile.
Like the one of you cruising 80 on 37‘s I love it!
So...
...what's the p/n on these bads?
edit: and did you regear the t/c, the 3rds, or both? Or neither??
4261135330
I’m in the process of putting low and high range gears in the TC, only because I needed to tear apart the TC to replace some seals so it would stop puking oil everywhere. Figured I might as well dump some gears in while I’m in there. But I’ve been driving it for a couple years on 37s and stock TC and diff gears.
Heavy. Inconsistent run out. Looks timeless and truck appropriate though.
Agree on heavy and looks appropriate. Ran them with 315 Toyo MTs for years. Had one that actually developed a hairline crack. Tried welding it, but the crack just kept getting bigger. Have now gone back to the original factory alloys and Toyo 255/85/16 MTs.
Toyota (42611-35330) are 17's... anyone have a part number for 16's?​
Wheel Vintiques smoothies are also available in either 16" or 17" with 4" backspacing. Don't know who's truck this is, but it looks hot.
1650386
Spacers required i assume?
Depends on how wide and tall of a tire you want to run. For 37x12.5, a 1” spacer with these wheels is perfect.
If you like to Steelies commit and widen them.
if you like to look get some method 307‘s with the faux bead lock.
Why widen??? The 7.5” width is perfect as a “poor man’s” bead lock for 12.5” wide tires.
