I would like to move the gearshift from the column to the floor, what is the best way to do that and is there anyone in the Ft Worth Tx area who is cheap but reliable..
Why would someone say this? Is it pleasurable to confuse the noobs?I would imagine it's a farily easy swap, but more than likely you'll have to change your transmission. Then you'll have to cut a hole in your center crowl, install a shift boot and bada bang you're done! I wouldn't think it should cost more than $500 for labor. While you're at it you should replace the clutch and rebuild the transfer case.
Don't do it! If you do, I will take the linkage off your hands.
Do you plan on keeping this truck even close to stock? If so, do not replace the col shift with floor shift.....the cool factor goes waaaay down.....
Back to lurking......
It is as easy as replacing the top plate on the tranny. Hard part for me was getting all the old column linkage off.
Post in "Parts wanted" for a 3 speed floorshift, I've seen them go from $25-$75.
Cut a hole in your tranny hump and you're done.
Ed
Here is a link to what you need. You can probably still get this kit new from Downey.
http://cgi.ebay.com/ebaymotors/FJ40...003QQitemZ130039278854QQrdZ1QQsspagenameZWDVW
I'm also wondering why anyone would want to change from col to floor?
My first Cruiser was three on the tree, I was in HS and my GF could scoot over real close to me.
I can see it if the linkage is shot.Personally my wife wants to drive my cruiser and can't on a column shift. In addition the bushings were shot and causing such sloppy shifts causing grinding it wasn't worth rebuilding for me. I like the original Column shift when its working to its potential. My first car was a 55 Chevy Sedan with 3 SPD on the tree. That car was fun to drive but we restored the car completely and shifting was a thing of beauty especially when your 15 yrs old. In my 70 model the PO butchered the shift linkage and I put in a 4spd tranny with the 3spd transfercase when I did my frame off which was nice combo.
Personally my wife wants to drive my cruiser and can't on a column shift. In addition the bushings were shot and causing such sloppy shifts causing grinding it wasn't worth rebuilding for me.)
