2nd Gen 4runner Lift
Richmond, VA
I have been looking but cannot find any lift for under 900. i am not wanting a body lift. where are ya'll buying yours?
i was afraid of that, thanks
Nah, check out Marlin's board, yotatech and pirate. I bought:
Front IFS kit for $180
Rear kit w/ coils and a rear axle housing + shafts and all the brackets $200
Front 3rd w/ 4.88's and true trac for $300
IFS lifts are cheap used since everyone is going SAS.
If you do decide to go with a body lift , I would buy a kit from Roger Brown.
I went with a 2 inch and it doesnt look to bad.
Also he now makes a poly body kit while your at it.
If you want to lift your 4Runner without spending much money then get the Downey Heavy Duty Rear Coil that will lift your rig to about 2 inches lift. This lift will cure that sagging rear of your truck. Now let me ask you this: How much lift you would like to add on your Runner? How about a 1 inch body lift from Roger Brown?
I fit the 34x10.5 LTBs with 1.5" Downey HD rear coils (more of just a sag cure than a lift) and a 2" body lift. Coils - $100 used. BL - $80. Total -$180
Also you can lift the rear end with stock coils from an 80 series cruiser, but then you'll need the panhard drop bracket and the brake lines and extension brackets.
customcruiser said:
$900 thats just crazy
i fit 34" ltb's with downey HD rear coils and spacers, SAW 25MM torsion bars crancked
for under $400
