Build '95 4runner TDI swap
Ill check out black haze.
I built some engine mounts today and tacked them in. I will pull then engine and finish welding them next week.
Everything is still fitting really well. I put the hood back on to check for clearance and had no problems. I have a feeling that the TD adapter moves the engine forward and the R150f is already putting the engine forward making everything easier.
I did have some issues with the passenger side mount interfering with the starter so I will have to fix that.
Drivers side mount. I had a lot of room so this one was easy.
This is the passenger side. It looks better in person but I didnt have much room to work with and will fix is when i pull it out
Here is the top view of the passenger side
This is the front view of the passenger side. I had to make it fit on engine and frame sides and keep enough room to access the mounting bolts.
The V8 yota starter is a tight fit. I was originally running a DCS adapter plate with a 3.0 starter, I had to notch my engine mount bracket a bit to make enough room to fit the bigger starter.
After running for a few, the much stiffer than stock 22re engine mounts began to flex a little more I also had to add some shims under my engine mount as my oil pan was starting to kiss my front differential under heavy acceleration. Like you, I wanted my engine as low as possible in the chassis to help keep the cog low and help with drive shaft angles.
I'm going to try to make a mount that allows me to remove the starter with out removing the engine mount. I havent pulled the engine to get a good look at the mounts as they are so Im not sure how Ill do it. I still have the front engine mount on the engine so if I need to add some support I can do it up there where there is more room. Since Im using 1/4" steel I think with a few gussets one piece from the engine to the frame should be enough. I think that if I can bend 1/4" steel something else has gone wrong.
Matt
I just pulled the engine and the good news is the drivers side mount looks great. It doesn't interfere with anything and will be very strong.
The passenger side looks...not so great. Im not sure if its crooked or is supposed to be that way. I built it is place so it should be correct but it looks odd. I have some ideas so maybe something good will come out of it.
I put a bracket together with cardboard before cutting metal. Not an exact science but I was able to get an idea of what I wanted before I started cutting metal.
I can indeed remove the starter without removing the bracket. It's a tight fit, but still one of the easiest starters to replace on any of the vehicles I've owned.
I built this one out of cardboard but the cardboard looked better. I saw some pictures of people who had moved the mount forward almost to the front of the engine and I’m going to see how that works for my setup.
I made a new passenger side mount. I put it at the front of the engine below the turbo. I need to add some more support to the frame side of the mount and its sticking out more than I would like but it should hold just fine.
I got the engine in. It looks a little high and maybe too far to the passenger side but the transmission seems centered in the tunnel. Now I just have to start figuring out where all the coolant hoses go.
Does anyone know what these two hardlines go to? The start up under the brake booster and end up going into the body around the rear passenger side foot well.
They're not fuel lines are they? What size are they? Not super familiar with 4Runners. The hose clamps and hoses look like coolant line hardware to me.
I'm not positive on the 2nd Gen but the 1st Gen heater is located inside the center console if memory serves me correctly. Check to see if you have vents and controls on the back of the arm rest.
I'm not sure if I posted pics of my coolant routing for my TDI in my build thread. If you need some pics let me know.
I'd 100% hook up that rear heat if you have it. That's a lot of space to warm up with just the front heater.
Don't expect heat from the TDI just letting her idle, shell have to be moving to build heat when it's sub freezing. This means your defrost isn't going to be all that great if your window is frozen.
You guys were right. It was the rear heater. I've had this truck for 2 years and never knew it had a rear heater.
I'm fighting my way through coolant hoses. I have almost everything figured out except how to make a 1.25" (VW) hose connect to a 1.375" (Toyota) hose. I haven't been able to find any reducing couplers but I was able to get everything lined up so the hoses meet.
I turns out that I suck at writing with a mouse
Matt
Are you using the VW expansion tank or the Toyota setup? Maybe the 4Runner is different, but I used 1.25" radiator hoses on both the VW and Toyota side of my swap, it fits great on my stock LJ78 radiator. Alternately you could take a section each of 1.25" and 1.375" metal tubing, weld them together and bead the ends to make an adapter. I made something similar when I had to adapt a 1.25" to 1.5" radiator hose. The beading can be made with a cheap electrical crimp tool from Harbor Freight.
I took a coat hanger and made a mock jig in the shape of the routing I needed.
Then a trip to my local O'Riley's and went through their hoses. There are lots of OEM hoses that are different sizes on the ends.
I wasn't able to find one for the top hose that fit perfect, what I did end up with was half of the OEM VW hose and an O'Riley's hose with a fix-it grey barbed coupler to join the two. They sell the coupler kits with 3 or 4 different sizes as a kit. Don't think orileys had them but advanced auto did, advanced wouldn't let me look through their hoses.
I realized that I just need 1.375 to neck down to 1.25 and I can do the rest of everything with 1.25. I bought some reducers that should come later this week.
I was trying to reuse as many hoses as possible and they change diameter through out the length of the hose.
Until I get the reducers I will start working on the fuel system.
Thanks for the feedback. Matt
I have one fuel line to the engine and two return lines. I assume on return is a tank vent and one is fuel return. Does anyone know if it matters which I use to return fuel. I'm hoping not to have to drop the tank.
Tomorrow I am going to try to drain my tank...Wish me luck.
What are you going to do about fuel pressure? If you don't restrict the fuel pressure to sub 20 psi you'll damage the tandem pump.
You can run a TEE to bleed the pressure off into the return line, the tandem pump will take what it needs but there's a bit of debate that one needs to restrict the fuel pump in some way so it's doesn't pump full velocity non stop and burn up.
Or you can install an old Ford/Chevy in tank pump from a dual tank system that puts out 12-18 psi.
I used a frame mounted pump from an old 6.2 diesel pickup GMC.
If you're lucky there's a fuel pump access under the back seats like there is on the 1st Gen. You don't need to drop the tank unless you're needing to access the fuel level sending unit.
