Stexag
Good evening mud. The 2F in my 1978 40 (desmogged) has developed a nasty habit out of the blue. The truck has run fine in the past, I completed a major re-fit of the truck in 2022 and since then drive with less frequency (shoot for a drive a month but sometimes don't accomplish that - so it does sit a bit). Things that relate to fuel/vacuum that were replaced in '22: carb rebuild (including ICS), new fuel pump, new fuel filter (and all hoses related to those), new manifold gaskets (factory), new brake booster, new PCV valve. I live at sea level and have driven it over Imogene without touching a thing - it ran fine there and it's been rock solid here - until now.
The Problem: Truck starts and drives normally. I will refer to that as the "Good" condition; all systems completely normal. Usually within a mile or two of going down the road it will *die* unexpectedly and almost instantly. I used the * because it doesn't actually die. It leans out to the point the I can't touch the throttle, but it WILL idle, and idle smoothly. When in this condition, which I will call the 'Bad' condition, I can pull the choke all the way out and the engine will spit and sputter but go back pulling hard enough to get me home (very similar to when the ICS is bad). With the choke pushed back in the engine will idle, but NO MORE than that.
So the problem is binary; it's either in Good condition, running fine, or Bad condition where it will idle normally (choke pushed in) but requires the choke pulled out to achieve anything more than than idle. 90% of the time the switch from Good to Bad is instant (chip your tooth on the steering wheel type instant) with the other 10% of occurrences being a gradual slowdown before finally going completely to sh*t. It will switch from Good to Bad regardless of time/temp, as in, it will do it on the first drive of the day or the 15th drive of the day. (I've replicated this more times than I care to count)
Once the truck is stopped and the engine is off - sometimes for a few minutes, sometime a little longer, but without fail... it will revert to the Good condition on its own and run like nothing was ever wrong. Then it's off to the races for a few miles before it happens again.
MY ORIGINAL DIAGNOSIS: This seems pretty easy - lean condition caused by fuel starvation/bad fuel pump/clogged lines/something in the tank. However - the fuel level is NEVER out of the center of the window. NEVER. In both conditions, with the engine running the fuel is steady, dead center the widow. That said - I have taken a 12v aux pump and plumbed it in the fuel system around the filter and pumped through the mechanical pump, but it made no difference. The fuel level stayed steady but the problem persisted with no difference.
Other things I've done:
Before I pull the carb off for a rebuild (because I at my wits end) - do the good people of mud know of another smoking gun or something else I should check? I only have one carb so once I pull it I can only dream of sunset drives until I get it back. At the current rate: if it gets as cold as predicted next week I might burn the truck to stay warm - so help is appreciated before I do something rash.
Thanks.
- verified ICS works good and clicks. Wired it direct to the battery to circumvent ignition circuit. No change. (I should note the problem doesn't lend itself to bad ICS since idle is the one thing it will do correctly in Bad condition AND unplugging it will kill the engine from idle in both conditions)
- checked vacuum - 20Hg vac rock solid at idle in Good condition, 19 in Bad condition.
- not brake booster - I've driven it with the vac gauge connected where the brake booster normally connects. No change.
- pulled plug wires on each cylinder while idling to look for dead cylinders - all fine, in BOTH conditions.
- pulled air horn off carb, drained and cleaned bowl, pulled/cleaned primary jet and first main nozzle. All clean.
- verified accelerator pump squirts fuel. Check.
- checked pcv valve - seems to be working fine, putting my thumb over it made no difference when in Bad condition.
- in the shop idling in Bad (lean) condition I used darn near a whole can of starting fluid looking for a vac leak, around carb base, around manifold gasket (above and below). Nothing.
- I did the paper clip test on the secondaries and they are not opening past the mechanical crack provided by the linkage. I am a flatlander, so it's hard to find an incline long enough to truly put that to the test - and the nearest overpass is beyond the range this gremlin will let me travel. However, I don't think the secondary butterfly NOT opening is causing the engine to lean out.
- it persists with the smog 'computer' plugged in or unplugged, if that makes any difference.
- the fuel in the tank was low when this started (last filled sep/oct) added fresh fuel today. No change.
