When I was a kid, a friend's dad who was master mechanic taught me this:
Always start with the basics.
In your case, if the motor has something wrong with it, it's not going to run good enough to pass smog no matter how well you get the carb and ignition set up.
What does the vacuum look like? F and 2F motors are prone to burning valves due to vacuum leaks. If you have some valve problems or bad rings, these are going to come up on a vacuum test. It also amazes me how many I see with badly adjusted valves, bad timing, worn out carbs and such, however if it's WORN OUT, you can't fix that by making adjustments.
I'd do this. It's awesome that your working on your own truck, I was student 20 years ago doing the same thing. For this problem, find a OLD mechanic in your area who's been around for ever (like the almightly pinhead) and pay him to diagnose the problem for you. Does not need to be a Land Cruiser mechanic, any oldschool and pre-fool infection (efi - computer) wrench will do. Hint, these guys like donuts and beer, some will kill for a good cigar. Sometimes you can find a younger guy with a lot of race car tuning experience, they are great too if you can find one.
Have him do some diagnostics on a 4 gas machine, run a vacuum test and maybe double check the work you've done. Listen to what he tells you and take it from there.
I once decided to mess with the Kugelfischer mechanical fuel injection on my old BMW and was screwed until I found a guy who could get it working again so I was once in the same boat. There was nothing wrong with the car except for all of the "adjustments" I made. Finding the right guy to fix it and $100 bucks poorer, the car was perfect so I quickly sold it.
You may have a tired old motor and there also be something that you are missing that is a relatively easy fix. I was once in a situation similar to yours that was caused by a bad timing light.
Of course, this plan impinges on finding a good, honest and highly skilled mechanic who is willing to help you out. Ask around, there is always one in every town. I've found the the Snap-On guy is a good source for local guru's. They tend to get around and get to know everyone.
If you want to have a go on your own, get a vacuum gauge from sears and do some google searching on how to do that. Here is a page for starters:
On Fire
Good luck,
-Stumbaugh
P.S. Your 75 is highly sought after in CA as they don't need to pass smog. If you give up, sell it here or trade for a 76 or newer that runs better than yours.
