Howdy! Here in Arizona, all 1967 and later have to test both sniffer and visual. They are dumb enough to do the sniffer first, but even if you pass it, they will fail you on the visual. I would think that Utah also has a visual, so cruiserhead75 should find out if he needs to replace all the smog junk. If so, that will make a difference in how the carb is set up by one of our Carb Wizards. I got flunked once on the visual due to a vapor canister hose barb that had snapped off and it had been super glued successfully. The car passed the sniffer easily, and all the OEM smog gear was intact and operational. Cost me $40 for a trip to the bone yard. JohnWith all the smog stuff removed, How does it even pass the visual inspection?
In CA they will not even test it if it does not pass the visual. No Smog pump, no egr system, no cat, etc.
