Hi All,
did a compression test on an otherwise strong running engine. Did not open throttle, so that may be why it's a little low, did not do wet test either. Engine is now out of the truck since it needs new main seals, oil pan gasket, hard fuel lines and various other small bits. Apparently this truck sat for the better part of 10 years.
#1 135
#2 130
#3 105
#4 117
#5 130
#6 130
Head gasket? I was also wondering how to tell if valves are bad visually when the head is off. Any guidance/pictures would be nice.
I have a set of toyota gaskets on the way, but would like to save them for the restore. Felpro any good? I know the public opinion is to use Mr. T. gaskets, but any real life experience with aftermarket would be appreciated.
This is basically a comprehensive tune up, I will restore the truck in the future and just want to stop it pooling oil. It's getting new ignition parts, water pump, rad and the rest will be looked at. Trans and transfer getting new gaskets.
Thanks!
Andy
#1 135
#2 130
#3 105
#4 117
#5 130
#6 130
Thanks!
Andy
