Mike, do you have the rear breather "port" plugged on your 2f valve cover? Thanks.
Works on mine. I don't see any marks on the inside of the valve cover to indicate any clearance issues. Just had it off last week checking the valve clearances.
That's a decent deal, I have been following the price of these for 37 years and that is average price just for the cover let alone, new gasket, oil fill cap, 4 grommets and acorn nuts, tax handling and shipping. Good upgrade if you are modifying your engine and not keeping it stock. JohnThere's a kit being offered on Ebay. Gasket, washers, and nuts for $69 + $9 shipping. All OEM. Seems high to me. Yes?
Shiney valve covers... so nice. Did you guys with the polished valve covers seal it up with a clear powder coat?
Hey everyone. So I have a post going about a 78 2F I am rebuilding for my 68 and am still confused as to whether the low profile valve covers will work. I read through this post, but maybe I missed it somehow... I am hoping for yes/no answers so I know how to proceed...
Question: Will a low profile valve cover from 80 and newer 2F work with my 78 2F?
Question: Will I have clearance issues under / inside the valve cover?
Question: I am having my engine shop completely strip, clean, and rebuild both the block and the head. Will my 78 accept 1980+ rocker assemblies that will alleviate any clearance issues?
Qualifiers: I will NOT be using a carb, or OEM air cleaner. I am putting TBI on this build, so I am not worried about external clearances, just the rockers.
Hey thanks for the info but I'm kind of confused. Which "replacement rubber gaskets" did you use?I did the same modification to my '70 40 earlier this year. Became weary of the leaking original valve cover. Spent $40 from another member, bought the gasket for a few dollars and had it sand blasted then painted. The threaded studs were to long so I used the replacement rubber gaskets around the studs and reused the original valve cover nuts. May not look like it should with the proper acorn nuts but it stopped the oil seepage and I believe it looks much better.
Also, saw where another member here on MUD added a filter to the rear valve cover port and added one myself. I realize the PCV valve draws fumes through the engine to the carb and I thought the filter was a good idea to keep dirt and crud out of the crankcase. Is my thinking correct?
I'm not sure if this addresses your question or not: I purchased a 1975-1978 OEM 2F Aluminum valve cover (used) from @65swb45 and it fits fine on our 1970 F155. The gasket that I used is Part Number 11213-61010.Hey guys, I was thinking of doing this to my 1.5F and am a bit unclear after going through this thread: Dave's later, shorter 2F cover fits this early F just fine but can anybody say for certain if the rocker assembly is different between early-F and 1.5F? if it's the same I'd like to do exactly as his pic above.
Looks like it can work, but I am not sure if he used the other rocker arms or not.Thanks, but I think mine is a bit different: I have a 1974 and was hoping to use the '80+ valve cover with the raised lettering (a bit shorter than the early-2F valve cover you've got).
