hoser said:Sincity, my tank has their standard single-wall bottom. But I believe Amando and others have special ordered theirs with a double-wall bottom for like $50 extra.
SINCITY100 said:Right on... I am such a dent-prone wheeler, I would need the doublewall![]()
Snook, Thanks for the input too, I remember hearing mention about how tough Armandos tank (not his 100, the GAS tank) was and how it took some pretty serious abuse.
I have been tossing the idea back and forth between either adding a spare tank underneath or carrying extra fuel on the roof rack..
I like the spare tank idea more...![]()
dclee said:If it's possible to do a spare tank under the vehicle, that is always the preferred method IMHO. Safer all around, no messing with fuel cans, no extra weight up on the roof, etc.
AFAIK (I could be wrong) the subtank setup on the V8 is the same as the diesel, just 2 necks below one filler hole.hoser said:As mentioned above, the fuel neck doesn't work like the OEM subtank
I imagine the setup is designed for the diesel primarily so the resitrictor is not there, but it would be a worthwhile addition if it could be fitted, especially if you loan your vehicle.hoser said:The only possible problem I see is there is no fuel filler restrictor in the neck--the kind that prevents somebody from accidentally filling the tank with diesel......One could fit an aftermarket restrictor but then it might not be possible to insert the nozzle at an angle.
Yes, I was thinking it was the same tank for both gas and diesel. 99% of the passenger vehicles out here are gas so chances are, everyone will put in gas rather than diesel.100 TD said:AFAIK (I could be wrong) the subtank setup on the V8 is the same as the diesel, just 2 necks below one filler hole.
i4c4lo said:Just a side note, some smog testing stations might notice your new gas filler neck and that it doesn't have the spring loaded little metal that closes the hole in the filler area.
I took the sender out and briefly looked at it. It is a standard 0-90 Ohm sender and does not have the extra low fuel sensor. When the fuel gauge detects low fuel, a red LED lights up. When it detects really low fuel (less than 5 Ohms), the red LED flashes--or at least that is what the instructions say. I have yet to run it that low.sleeoffroad said:Hoser, I just fitted the 13/15 gallon oem subtank to my truck. However the standard Toyota sending unit that came with the tank is different from the 80 series in that it does not have a signal to show the tank empty. In the past we used that to turn off the pump when the 2nd tank is empty.
Does yours do that? What sending unit does it use. Or is it part of that fancy switch/guage?
hoser said:I mounted the aux fuel gauge/filler button on the center console. I initially wanted to put it in the instrument cluster opposite side of the dimmer switch but after seeing the brightness of the LED's, I didn't want to have it glaring into my eyes at night. I opted to put it in the center console, far enough away from the AHC controls so that I didn't accidentally turn the pump on. While I had the console open, I decided to mount my fridge/freezer temperature gauge.
Overall, I'm happy with the product.![]()
