Rock Slider Install
I took off my running boards the first week after getting the GX (April 2021) and eventually ordered rock sliders during a Thanksgiving week GX shopping spree (Nov 2021). I went with RSG angled rock sliders with kickout based on appearance, price, and my fondness of the ‘RSG’ name since it is also the acronym of my grad school research group, the ‘Remote Sensing Group.’ I went with the cheaper steel option. I also googled for a coupon code and found a $100 discount.
I soon discovered that most of the bolt holes were filled with dirt and rust. Most of the time consumed by this project (or at least perceived time) was spent cleaning out these holes with wd40 and tap. The photo below shows a nominal hole bleeding out dirt and rust during one of the tap/wd40 spray-wash iterations. Depending on the torque needed to turn the tap, I turned only half to a couple threads before taking out and rinsing with wd40.
The sliders came in a cardboard box that was pretty torn up upon arrival at my door. They were pretty well wrapped, but had at least on ding/scratch on a corner - no big deal.
Dolly and scrap wood make solo installations a breeze:
Never can have enough antiseize, right?
I torqued down to the prescribed 24 ft lbs and this pressure slightly bent the supplied washers into the slider bolt holes. I appreciate some slop in bolt holes for ease of installation, but maybe this was too much.
After a week or so, I took the time to carefully trim the running boards. I watched the CBI slider video walkthrough for guidance on disassembling the running boards. I surveyed instagram photos of GX owners with RSG angled sliders for guidance on how much plastic to trim. Then I iteratively cut more off as needed (3x for the first side, 1-2x for the second side), each time reinstalling the plastic. It was not fun, but worth it for me. There is contact between the plastic and slider - this should be fine. Here are some photos of the finished product:
