2017 GX 460 for North Central Appalachia
When I attempted to download GAPPS to the VLine, I lost my wireless connection and couldn’t get it back. I unplugged the main plug to the VLine for a minute or so and all is well. I also added a dedicated USB for the VLine as well as a few more. But I replaced the existing USB / Aux outlet and the the cigarette lighter socket all with USB's. I’ll take some pics tomorrow. But this is what I used in place of the USB / Aux port:
Amazon product ASIN B07G757Y2D
Pics of where I installed my extra usb outlets. And just FYI, I'm replacing the round socket with the 2 USB ports in favor of this one so I have better charging and I can keep an eye on the battery.......
Amazon product ASIN B098SY1LPN
I like the C USB socket. Most everything is moving in that direction, at least until the next "USB" comes out.
Yeah, that’s why I decided to go with that one. Putting one up front and one in the rear drawer set-up. Those are supposed to be here tomorrow.
Tire/Wheel update
During the week of Thanksgiving I ordered a bunch of stuff that I have been researching and benefited from modest discounts.
  • RSG rock sliders (w/ kickout, angled),
  • CBI covert bumper, front and rear skid plates – the freight cost seemed absurd but calling in helped reduce this cost since they were able to get an updated/different freight quote.
  • TRD Pro wheels, matte black - from Passport Toyota in MD
  • BFG A/T KO2 265/70/17 (I ordered these from Tirerack after I knew the delivery date of the wheels)
Only the wheels and tires are in so far and I got them installed a few days before Christmas. Rubbing summary: I removed the bolts on the front wheel wells that were sticking out and replaced them with stainless steel screws that had smaller and smoother heads. There was a small amount of rubbing in a few places and I used a heat gun to take care of them, one at a time.
The spare won’t fit in its place, probably due to the Lexus hitch. The shop attempted to put it there, but only got it in a few inches – and left me with the result 🤣. I am keeping it in the back until I figure out what my options are and what I want to do – Probably remove the hitch and stuff it back in.
Before:
jclC9SL6o9Tz77cBNxQM0k-Ezqh0-vOpxW0i4MX7Jo9VnTooWyNb-triFzLJmuSyhnYdV_FVo3dNbT6AZdleHeuoQLFP4e4P428t00t4zFuE8MSK4kWC0xWCjrGulrejWV-mwepB
After:
oWj56qBVmqGRIv94x8e0YTzUPodRn7q663MltgUbjjEDLvs-ArUroNu_Db6IZ3mndLvEe2trICnkNJkQzDDVywdnd954vwuQLH8Q0EfJ9bGleR60sD7Efgbk8pztbw3ghqwP_peD
z_60VVyrWgH6Bj0T7OE8P2xTnHFbGbrMCVhmCcufFh8KhDEaA4u2WjKVz8_Y0SaBF6IVKuu-NKTEax-3sPvUKSqoWBBXKIEqDccnewmtWig_KP6MzcmygBDWmJqGL6okb09-o2-g
They sent me home like this 🤣
EvuQ9aTJdF9K5FLX-pKtsoS_0PQp1LLI0DL7XQ-PTDoHJ9Jo1fHZyRvStrg2g3xPMZ3ObLPNZji0HoX8rHMN35y_0nzDyEVQnN9ca3xGWPKE80ncNqaNZ-EVccm5CiXf50qrRZnu
I'm surprised a lot of people can't get a 265/70R17 into the well back there. I have the factory Lexus Class IV hitch and mine fits with a bit of room. Obviously tires have tolerances and variances from tire to tire, but to send you home with it dangling like that... lol. They should have at least offered to throw it in a bag and into the back for you.
I’m a little worried my 265/70/17 Ridge Grapplers won’t fit under there or it’ll look like @landsat6’s in that pic.
I think I could stuff it in if I were to deflate it more - I had to deflate down to 20 psi to get it out after the shop cranked it in. However, I didn’t know if touching or putting pressure on sway bar was a good idea - experts in the room? I’m fine with the TPMS warning if that’s the only negative. For now I have it wrapped like a db in the back.
I deflated my 265/70/17 Pirelli down to like 7psi and tried squishing it with a ratchet strap and it still wouldn't fit past the sway bar. I *might* be able to just smack it into place with a dead blow hammer or something, but A) it will probably still contact the bar and B) will need some tool to pry it back out if I ever need it.
After reading all the efforts everyone is doing to squeeze an oversized spare into the stock location, I just hope you all are also considering the effort and/or tools needed to pull it down and inflate it in case the need ever arises to use that spare.
Agreed, @r2m
Does anyone have insight on the question if contact or pressure between the spare tire and the sway bar is a bad idea or may cause latent damage elsewhere under certain conditions? I'm not going to attempt to squeeze anything until I understand this, though searches don't reveal much or I just have poor search performance.
That's why my spare lives in the garage or on the roof rack until I find a swing out or something.
Before kdss spacers I had my 265/70/17 wheel crammed in there. I had to lay on my back and use my knees to push on it, alternating from front to back while cranking it up into position… not ideal at all. I had the class 3 receiver and it barely fit.
In the nominal position, it was not contacting the sway bar, however there were rub marks where it had from time to time. I’m guessing that happened when off roading. When the axle droops, the sway bar moves up, contacting the spare and stopping any further droop.
After installing the spacers, I had plenty of room for the spare. It cranks right in and there’s probably a good inch plus of extra room between the sway bar.
Rusty bolt replacement update
My GX seems too new to have rusty and corroded bolts in plain sight. I noticed the first batch when I installed the dash/rear camera (earlier post). To start, I ordered:
SCREW, HEX LOBULAR 9090148002
BACK DOOR STAY; BACK WINDOW STAY. 6896120140
I first replaced the hatch stays:
RvZ-8jWAF52yPZCD_SVLbysY8pEJMfVN1XRXwg8jeoo89uI9DPZL1Bs8ZXHCyJ4HOslFlRhhmVZ4fx14ieRCxXRO43lYmPPIQXLCY_3QsgnnCPqrjhgQB-iEzxjy_OGYV7y2kh2UYh_OwdPzVA
rvCx2iB7g_1pH4ZmFVMGiIJ_GCiVvRVe7M0W5cPOFotiKt5nHpkur4xXBAQr4eqqy5JZtet5RsJeFdL9XbhLi_TAo8WZsZEi2OvQLJxJGnzUK0EOMc5jbeez6HP0upBz1ZZdtq2vcSUgOUWQlQ
Ut621MPXxZLNdMLiZEun6hb7bEvebFuenCZvoAlxdQTyuQaFrloLrRgJDtApmLSo2Qpb-0o36lC4ES0kyrbEzSubDzKSc2Lq2nmPMHGNsKdl9Al-j2HhddPul9CYp1DLeEZVrl8Qj2Gv2wzAag
jf7wxd0el8fDTT5zgjEO7Q6gF-0SfeQ_KSvjxSlKOJjVf87FXIUmmlXTN7cLFROhEn6NHdwIxaaKerwt-6GbAi11i5oEjOcgmFtC2T-RjwNzaOOjS1e7xGq3-y-xU9P1UoGrZbnqBrXSamWlHQ
I coated with Fluid Film the bracket that holds the piston to the stay:
CDQbaU86dgKEPG7LXUtp7fxbHrr_SiXTaigRpmqfalZxYxxFgsAcRKjMlWBk8lZ_3xface2Y4k_-Ptx9DkxlGi32nNWSTp6YBInrIaBkz_B4BYkw4gpFS5kHEExuCsronWCJAcgHhkEfnvLjtA
Next rusty part replacement - I noticed that a couple of the ~1.5-inch flange-type bolts that hold the back hatch glass were corroded when I was installing by dash/rear camera (see earlier post). Even though they are covered by plastic trim, I was concerned that the corrosion may spread. I provide a few photos below:
Photos of the corroded bolts (right is drivers side, left is passenger):
u0fiq41IEUYTPorIVHbA6jjeac_GeqGGAJSvfn-Gu_Vdeju8_BNdgEugSwLWOl2Anwd5dgDgf_17-toDAFjs0Y-u_WFQizWuwN-l4tku9IgSVzDgn0r-QMfoGdg-x3px_k2IUfSnVQo7YAY2SQ
HedpFuqmKGk7uEbhKwN2Ypv5vJDyAqh8dJr1Or287od3_1AzC-uuZPs8EpSbO-C9e2fYrojHz-6IHO66OmWysHXvjxhdQzrRll2nLHzWgw_1YpGUCE5leQnHVpp2QQAL6keWFXXsgisAMXUFVg
I replaced one at a time (left photo). And used antiseize (right photo).
usjlwTSu9ykrQ-8--G__a3_J5LNZaaeT2_EbRPztIWgs21jicY3upo9AM1AV4VP9CehdHMGeFk4TLKWzKZxwn3SsrFdAlsDeSPn9UP0o2vEB5X28c9mWLACuKoy32lBaUq_yPMNYPAfv1v8Ngw
W1jhHIdvKd2jsrP6l0Cpc4tWPKEjyy4YZGVFWM1vFUZ2UeTtngXTAYWpjJUDUR7pro_g7lCGmQkpI3mAIyimmBJ93ODHYj84FqpUIgZKmmXxXezHYOXGvmy1ynxjUDzzDYEKGJorTbi3G7UkfA
During these stay and flange/‘lobular’ bolt replacements, I looked up into the seams of the rear fin/rear wiper assembly and saw signs of rusty bolts. There were not too bad and too many to reasonably replace, so I brushed them and coated them with Fluid Film. Some were worse than others. Here are a few photos:
uHdR_ZDPMcfZQFeF9IqVfcLLkpjm_LSvMitoaWFnmnBgv2ZAMNtap2rNUDXMNRmf-9RZ8azdtgqM9jwZ0y-qi5Q04CvqVVethJc2GZ-0QSx0aTa26SxJ0d-XBLBqZZiT_VzsFNnWAL6WzaCzgw
Now I have a can of Fluid Film nearby whenever I do anything with GX.
Rock Slider Install
I took off my running boards the first week after getting the GX (April 2021) and eventually ordered rock sliders during a Thanksgiving week GX shopping spree (Nov 2021). I went with RSG angled rock sliders with kickout based on appearance, price, and my fondness of the ‘RSG’ name since it is also the acronym of my grad school research group, the ‘Remote Sensing Group.’ I went with the cheaper steel option. I also googled for a coupon code and found a $100 discount.
I soon discovered that most of the bolt holes were filled with dirt and rust. Most of the time consumed by this project (or at least perceived time) was spent cleaning out these holes with wd40 and tap. The photo below shows a nominal hole bleeding out dirt and rust during one of the tap/wd40 spray-wash iterations. Depending on the torque needed to turn the tap, I turned only half to a couple threads before taking out and rinsing with wd40.
JejB_QFTialfrEBT7_4iLtIKiF6AX5j1ClRQL8biGB2zAT4ZTggtkXYyWBnBXVc6khpPMBF9yvtf4O6_0vYAxzG7jQW7gutVl0Pfjj2CjkMUpl9UldPiEb8qZK1e0V2_WLtcNX0WaaV0Cfk4Mw
The sliders came in a cardboard box that was pretty torn up upon arrival at my door. They were pretty well wrapped, but had at least on ding/scratch on a corner - no big deal.
quVnN_1MxpkDSffb2B2YWr87d0qUmrXRgRyrE5Ejwvo2S2bIUQFkXEcvT4Ja9rvWFfxlv86rcoMDgcOE5-Qprr_0AdSncd-DPZdHcL2Bb_d3R0lP3AlTiSebIZi86pk0kqF0YDcvi_7W173jIg
Dolly and scrap wood make solo installations a breeze:
AwP47c-nlB653b_wC6fuSChEz6jj9U-VzieyeBYlZau9uL8F4A6ZgJtC3ikuvCkjHSleC4_VokXJX-pgedApX3VpBcVtCxo2ReHYXLCUoOSIK7-xitN9fIBslSilFoEaJ_V2spcPSGrU5UsLYQ
tdQO2DQ_G3av_g3uaFxBmbMdmJ5y0ZsKXd26lSVWLd3qPKEiGaSwCdmpnB4-pg7fwKnQYIHQFUnnBKHltyXrla4BDhqOPl6sIjj9hPfjarZVPqdhQ_zRXNytAe_Eu0XrM5CyuYgMVB61-GawGA
Never can have enough antiseize, right?
-Xgb2sKbbYOnpMcVg3GxLQJmunWdt1DWf4pogC4-TAY16hsXC6BlBMdGwplRprLX8CKKkIiCocMkkGl3HvcKRtjfPmaQB8u-wNOPhS73LtOZQDVxQ0ZBv5XQkQj70_A44hVtJtohBc6OasBuIg
I torqued down to the prescribed 24 ft lbs and this pressure slightly bent the supplied washers into the slider bolt holes. I appreciate some slop in bolt holes for ease of installation, but maybe this was too much.
After a week or so, I took the time to carefully trim the running boards. I watched the CBI slider video walkthrough for guidance on disassembling the running boards. I surveyed instagram photos of GX owners with RSG angled sliders for guidance on how much plastic to trim. Then I iteratively cut more off as needed (3x for the first side, 1-2x for the second side), each time reinstalling the plastic. It was not fun, but worth it for me. There is contact between the plastic and slider - this should be fine. Here are some photos of the finished product:
btHlOPH9rFCgZ4gENYPMSrko3eXCAmJNpsbTMo0sXkbeTJKk1d0U3JkcJ2hCuOQT-devDq4CP99NbXRrgmLXXf86lXLTdu2u6gDLakSLp5BqbpL_1Qb4SISzowE31Mt-l4lSWvwXOuwI0rRO1Q
O8p0jXel5cA6yfdOWPL_viKMQzjGi8yJ9iSgjUn08L6VogTKAKMd6O7KJiKzz1RLA57WCHNHdx31LzIfcKmgZmsU50GnlTJURtJaq-p4gfLG_p0SaHsgtKvQVBG09b8whFwK3e_Psuh0852iHw
-G1RDplh_cQbUuLD7Cuth6tSHD1XYK3-uzURCHEn_puiyvQl752vLxtvHNQ1mOrQeXoqrdkPKtHkQw9R52vOmr4EBINa8-RJ-0mSy9mng2wMGC7ZgvllA_2Hwy-vxY_sCskqjC9XBBp8m-7NNA
I have the exact same sliders on my rig! Love them! They stick out further than my old Metaltech so they are way more comfortable to stand on when opening/closing the RTT or my wife ingress/egress the vehicle. With the Metaltech's, I could only get my toes on the slider to stand, and I'm usually wearing sandals with no support, so with the RSG I get a lot more area of my foot to stand!
I also ordered grip tape:
Amazon product ASIN B01C68H8V2and taped them up for mud, rain, snow, etc. so they're not slippery when I'm on them.
This shows the Metaltech still bolted on and the new RSG on the ground waiting for install.
Parts left from front bumper, skid plate, and suspension installation
Is any of this worth keeping or trying to sell?
  1. Original front skid thing
  2. a) brace for bumper part (I think); b) original UCA
  3. Original front skid
  4. Original coil overs and rear shocks
  5. a) brace for bumper or running board; b) brace for bumper or running board; c) frame brace taken off for new skid; d) bumper standoff/spacer
  6. a) inner bumper plastic; b) wheel well pastic
z11-NHR8f2LFmcaEcD3cfxuzW53DBeWeIHzlFJSvPtd9Zf7qu3KCHmc6EdB26YrAGglpECPgsuzm3xoKZ_-wMJZUHiEs-paO6Rtlr0_qb-sQtxfzfzZ0p9MQhDA5k53WExGcLMsLyX8Xu_bg19jMUy0
0178bF8ZUCXuMkuCDAz1qz-PBJ6Qnmz93SeyUJsJaleh6a3Op_KbOtA66Vud-Pcwv0fsbI3I325gy8vgIuCRNQQB14cRFJ4pHN9e5kxmjSTFaQL-uMiTpAIAvS4b0yqcKR5HCDwYLM6HOE_q4oO_kkw
7IfS6CW9buys5IsD1Hwb8J0kaJQiW43a1MGReKblj2gZiYTa0znMIq1JHEvscIcKsjBJDtQ7CMRD7PUuErsGwoxdzf-nRhQpshWsgpv6-7gPR5NINJVVXFkf_1fWAjvT_QAHBLMHeG046OHftZdsw70
Ldn1oHNeqV1WGaOUWV1E0VKtLccq7b65eiSWnWJZP9jHzWcebrv0G7yq33BhHSGx4qUxEAztd0nhnM6Io6-Uiv0olI_aocEB5nT8tFm_UuXl176___TFfHoz9KTuuu2d__CXjqZ2jas0C6whXZ7nb8o
wAePqr0srOpifrZL4VnClBGD38vMP7--XSKz3XmFWzVLwEOl96E-65ctNRc95yIrC2eu109-yXy_E7Vx099UNN-06ctwEw81s_Zw5ooCjflaIrmKTt6LpjorgCJ-isra5XPKpB55MtxL48KwxXjC1AA
Q_cDDrEAUEfaKQNVq7Z9u7eXBf_1vI_WKHVfVy9n43KzqO6ZIlfn4An1bsLus-_58FUifyQvU0DlFuoNhSRKfRZ70MM11F2ly0pT_R0tpXtx5-wXJHNSaQi3Bt0nWOSwq4Zr7ffP6W9oys1VhwjKGgM
  • Like
Reactions: r2m
Question: are you a "horder"?
My father-in-law would keep them.
I'd put them up for free to anyone who wants to stop by and get them. After a month or so, there will be an extra heavy trash can on the curb.
