2013 LX Battery/Alternator (2 Viewers)
My local dealer wants $438.89 plus tax for alternator part number 27330-38140...:eek:
You might end up having no choice but to buy a new alternator.
You do have a choice on what alternator you buy. And now you have an excuse.
I've used these guys a few times for fire trucks. Good product, fast shipping.
-FYI
Does this method work on the 200?
I don't like the cut scenes where they transition from the part being INSIDE the engine bay to OUTSIDE the engine bay. Always makes me suspicious to their claims of how "easy" it is. I will gladly defer to someone who's done this, but I appreciate honest people without the movie magic of furthering their shill/hits/money train.
I wasn't able to pull mine through the passenger wheel well. Just wasn't enough room. I've got some more notes on my post regarding my alternator replacement.
New battery is in.
Alternator is not charging, just picked up a new one from Toyota.
About to start tearing it apart.
I appreciate any and all tips on getting the old one out.
About to read the thread linked above before i get started.
It's not as hard as you think to get the radiator out after you pull the two large hoses, transmission cooler hoses, and cowl/fan.
There are four bolts (one per corner) and it lifts right out.
Thank you for this info.
One question. I just want to confirm that you did not have to remove the radiator?
Nope. There was enough room without the fan, shroud and hoses in the way to pull up and out.
Pretty sure I didn't need to.
Ok thanks.
After getting everything out of the way I think I've got decent access to the bottom 2 bolts but the top one is making me think I may have to take the power steering pump loose.
The pic is looking in from wheel well.
New alternator is in.
Voltmeter shows it charging at 14volts.
Battery light gone.
Here is roughly the steps I took.
1. Remove passenger side wheel / tire. Take out two plastic clips and rotate the wheel liner up out of your way.
2. Remove Bottom Shields/Fan/Shroud/Radiator Hoses and Serpentine Belt. I also dropped the sway bar (4 17mm Bolts) to give more access from below.
3. Loosen the transmission cooler hard lines by taking the bolt out of the front bracket (On Alternator). And the bolt on the backside bracket close to transmission. *This step is necessary to give yourself room to get the bottom 2 Alternator bolts out.
4. Remove bottom two alternator bolts. Even with loose transmission lines this step is still a PITA. I attacked this from below.
5. I wound up removing the power steering pump. (2) 14mm bolts come out through the front of the PS pulley. Then a prybar through the wheel well to get it out of its bracket. I used a coat hanger to hold it up out of the way once it's free.
6. Once the PS pump is clear, it's a straight shot from the wheel well to the remaining bolt and nut holding the alternator in place.
7. Lastly I Disconnected the plug and 12mm nut holding down the power terminal then fished the alternator up through the front of the engine bay on the Driver's side.
This took basically a whole day for me granted I'm not a professional. I'm sure there are others who could do it faster with less steps.
I was thinking about potential reasons my alternator failed.
The bearings showed no signs of failure, there was really no discernable play in the pulley or noise from the unit which I thought was pretty impressive for approx. 160K miles. To be honest it was in pretty good shape once I got it out.
Here is what I think happened. Pure speculation.
I replaced the radiator in the truck a few weeks back (probably a month ago), and did not replace the skids as I was also planning on changing the oil a few days later.
Well those "few days" turned into a month that the wife drove around with no bottom shields... through multiple springs showers etc...
I'm sure it was time for it to go, but I also find the timing pretty coincidental.
I've seen enough water fording videos on youtube that result in a bad alternator to know these things don't like water.
If anything the added moisture probably helped end the life of an already failing regulator.
Shields maybe more important than I thought due to Toyota's decision to place the alternator so low in the bay.
My .02 cents.
