Did you use the Lexus badge off of your old grill?Next, let’s ditch the faded OE grill and go for the updated Kazakhstan sourced F Sport like grill.
No, the Kazichstan Grill came with a badge.Did you use the Lexus badge off of your old grill?
What are the details on the grill emblem? 175mm?Next, let’s ditch the faded OE grill and go for the updated Kazakhstan sourced F Sport like grill.
Are you asking me to measure the emblem, otherwise I don't know what size it is I ordered it with the grill as I said.What are the details on the grill emblem? 175mm?
I want to retract my comments on balance the balance beads. After a few more camp trips I decided to remove my wheel spacers (Spydertrax 1.25”). My effects backspacing with the spacers was 3.25” (wheel BS 4.5, spacer 1.25, 4.5-1.25 = yup 3.25). It was clear a firewall chop was required with 3.25 and I’m ok with that, but also wanted to suck these wheels in a bit, so deleting g the spacers was in order. Moving along I noticed LESS a lot LESS vibration at speed,A couple of updates, I wanted so bad for balance beads to work so I saw what I wanted to see in the YouTube videos and was hooked, and yeah no those don't work in my 37's, if anything they are worse than my not-so-great balanced tires. I added 16oz a wheel per bad math calculations. Application Calculator - https://www.counteractbalancing.com/application-calculator/ calls for 14 oz with 37" mt's added 2 ounces for the wheels extra chunk and landed on 16oz.
I opted for balance beads because I was in a pinch before a trip and was mounting up some new wheels, with no time to get to a good tire shock for good balancing I thought I'd try my hand and potentially only waste $45. And waste it was.
View attachment 3585246View attachment 3585253
Got some time to take some rear measurements and check for clearance.
