2006 Cold Start: Jake Brake Sound; Cold Start (1 Viewer)
Atlanta
Morning all — this just started after some recent maintenance.
My 2006 with 302K miles was getting terrible mileage (~6.1 MPG) and felt lethargic. P0420 popped up, so I replaced the O2 sensors, spark plugs (OEM), and Denso coils — all torqued to spec (plus a hair on the plugs).
The next morning on a cold start, I heard the Secondary Air Injection Pump run, shut off, then a few seconds later came a deep, two-beat rumble — like a distant Jake brake or a modern V8 switching to sport mode — lasting about 2 seconds. It happens randomly, but always only on the first start of the day.
I've ran back through my checklist, and vacuum hoses are good, and everything plugged in. This doesn't sound like the SAI Pump, however I guess it could be?
What says?
Any error from your OBD scanner when you ran diagnostics during or after the symptom?
P0420, which was accompanied by terrible performance and sub-par fuel economy. No codes after, and doubling of fuel economy. I know sit in the 12's.
I don't have any experience with that noise or SAI pump , but I know I've seen some folks talk about a small filter in the pump that can sometimes get sucked in. I doubt thats your problem, just trying to add any relevant info.
Since the noise never happened before and then started after maintenance I'd think to focus in on whatever you touched during repairs, but I don't see how plugs, coils, o2 sensor could lead to these symptoms...
What about like heat shield on the exhaust or something like that. Is it a rattle? Jake brake noise, hmmmm
I think I may need to try to capture a video of it, it's a very unique sound, but the best I can describe is a jake brake sound. The engine RPM calms down, SAI cylces on>off, then this new induction sound happens. It's a very deep grumble, I guess induction sound might be a better term
It could be the SAI, not discounting it. Usually for VVTi 2UZFEs, the SAI issue comes up during cooler months where it has to stay ON longer in respect to the O2 sensors warming up the catalytic converter temps. I’m curious what was the your outside temperature when you first got the P0420 dtc? And do you happen to have the Hewittech’s SAI kit on your truck?
It very well be the SAI Pump, potentially running at different RPM's and creating a hum, a bearing could be going out. P0420 came on when it was HOT, ~100*F, 90% Humidity, on the highway. I was coming back from the airport, so it had sat for a few days. It's in the 70's in the AM now, when this happens.
I do not have any SAI blockers, etc. This is, from what I can tell, the OEM equipment from 2006, with no replacement parts.
On the bright side that’s 300k+ solid miles before it went out, pretty impressive to me. I have the Hewitt SAI bypass kit installed around 4 years ago and haven’t had any P0420 related issues since. It basically bypasses the SAI motor and alters the signal to run natural aspiration during startups especially when it’s cold. First time I experienced it was 4 winters back and it stayed on limp mode, no unusual blower sound. After the install engine operated normal again.
Could it be the computer opening the throttle plate wide open to correct for some mixture abnormality?
I believe that would produce the sound you are hearing.
YES! I'm not the only one! 2006 lx with 215k now and I've heard this less than a handful of times but can't seem to track down. Jake Brake is the perfect way to describe it. Lasted only a few seconds. For some additional data... my SAI was OEM replaced at Lexus 12 years ago at 88k. I'm considering the block plates or even the serviceable filter mod but holding off until I have a real reason to take the intake manifold off.
SERVICE: OTHERS
DESCRIPTION: ~|~CUSTOMER STATES CHECK ENGINE LIGHT ON VSC & TRAC LIGHTS ON ~|~P1445 SECONDARY AIR INJECTION VALVE STUCK CLOSED CAUSED BY DEBRIS FROM AIR INJECTION PUMP BLOCKING AIR SWITCHING VALVES ~|~REPLACED AIR PUMP ASSY AND THREE AIR SWITCHING VALVES ONE TIME GOODWILL FOR PARTS ONLY-GUEST TO PAY LABOR PER DSPM AUTH# R0916C
What says?
You may have multiple issue going on.
The sound could be SAI pump (blower). They'll make a sound, as they shut down/turn off. Typically, if we hear it. The filter within it, is gone. The sound is usually ~90 second after cold start up. SAI pump, does not cycle on and off, after warm up. They just turn off.
Another sound we hear, is fan clutch. We get a turbo sound on cold start. About 90 second as clutch release from fully engaged, reducing spin (turbo sound) on fan. Others sounds are; bearings of tension & idler of fan belt and timing belt, also alternator. If HVAC on Auto, AC compressor is another.
S.A.I. TSB out years ago. Call for, replacement of pump and the 3 switches. when certain DTC pop up. What happens is; the filter within S.A.I pump, shrinks and is suck into imperller. It's foam rubber and the dust it has collected. Is ground up and pushed through the S.A.I. system. All the way, Into combustion cylinders and on into CATs. With no filter, it continue pushing/blowing dust on every cold start ups. On the GX recall, for S.A.I. filter. Toyota sighted, the filter may be affected by moisture. I now have very strong evidence, it is. S.A.I. filter are affected by moisture and server climates. The higher the humidity, the sooner they fail. You don't even need to drive/start the engine much. I recently found a 25k mile 07LC, with bad filter. In fact, all foam rubber was bad. Form end to end, meaning engine compartment, speakers, etc. The S.A.I. foam filter, lasts the longest, in mild, dry climates. But all will fail.
I've seen, three different OEM S.A.I. pumps. The difference, is the filter. But no matter which pump (filter, the filter will fail. It a dump design, to have a non replaceable filter. Most if not all Toyotas, after 2005 have, S.A.I.. There's is a very simple answer to this issue. Easily replaceable filter.
IMHO the block-off-kits, are not the answer. In fact, those kits, that tap into MAF. Are causing issues. They'll also not street legal.
The S.A.I. has nothing to do with MPG. Except two possible I can think of:
1) Switch stuck open. Which will/should produce a DTC (CEL). Would dump extra o2 into cylinders. This should result in limp mode, if not; MPG may be affected.
2) Dust dumping into cylinders, will result in lower compression.
SERVICE: OTHERS
Typical of high humidity climates. TBS require all SAI replacement, nice parts under wrty at 127K miles.
I use my directional bore scope with 6mm camera, to inspect these filters:
As long as filter still in view, you can wait.
If to dirty or brown (old dirt foam) kept very close eye on.
If gone, either replace S.A.I. pump or do my replace filter mod. You can do a block off used OFF-Road only (Trailed to off road). But avoid those that wire in, especially if to MAF.
Filter of S.A.I pump (blower), gone from view. In this 25K mile 07LC, out of Gulf coast LA area:
Cap removed.
So nothing else done?
S.A.I. SW Stuck open DTC. Is the one, that place vehicle in limp mode. It a safety, so we don't continuously add o2 to cylindres (lean fuel mixture). Which, if due to filter being gone. Also means, continuous dust introduced.
Did you ever do a compression test? Numbers?
