Media 200 series picture thread (65 Viewers)
Photo/Video/Audio threads
Y62 Patrol and 200
series
I did the same fun stunt last year at the FJ Sumitt. It took two FJ Cruisers- one behind the other, my Maxtraxsand a lot is shoveling to get me out. A bit embarrissing but one guy got to use his winch for the first time. We had to snatch block the first truck to mine to finally get me out. I'm sure there is a pic somewhere out there...
2 Jeeps (one as a deadman) tried to pull me out backwards and couldn't move me an inch. So, we finally settled on a forward pull and I got to use the 200's winch for the first time which worked easy enough. Last time I was stuck in the snow with the 200 it took me 45 minutes of shoveling to get it out...no fun.
@GX-R man...why must you tease us? Not fair...
These are everyday sights in the gcc, if you guys fond these a tease i wonder what you'll think of the ridiculously modded ones, @GX-R maybe we should post up some of the crazier 100s and 200s ;)
Trail ride in Nelson county / salt springs KY
Nitto trail grapplers 35x12.5x17
The LEDs are day light mounted to my front bumper. Really nice lights.
What are you planning for your rear mudflap Willy?
Not sure right now. Got a suggestion?
Given the inward cutaway angles to the underside of the bumper return wings (what a mouthful) I'm guessing you might want to reinforce the rubber flaps with some small steel backing plates to provide 1. fixing for rubber and 2. support the outer edges. Might not be such a issue. Its a little hard to tell how far the lowest points reach in toward the center from the outer tire line - and the height of the bottom edge seen in that incredible flex shot above :clap: might be making it look bigger than it is.
