Just did this install over the weekend and noticed a couple of things.
When using SPC upper control arms, you'll need to source bolts for the brake line bracket that bolts to the UCA as the OEM 200 bolts are larger than the Tundra ones. I used zip ties as a temporary solution to hold the brackets.
The LCA shock bolt seems a few MM too long. I'll have to compare with the Tundra bolt to verify, but I feel like the Tundra bolt should be on the parts list at this point.
Also, I am being a cheapskate and holding off on nice shocks so I reinstalled the OEM struts with the addition of the OEM strut spacers and ride height appears to be pretty similar to stock. I'll take measurements once I get back to my flat piece of concrete.
Lastly, has anyone that's done this install had issues with a torn/ leaking CV boot?
I used all new parts and used the FSM for the install but ~100 miles after the install I have grease sprayed out on my LCA and frame from the LHS inner CV boot, but can't see a tear in the boot.
