I don't see why it wouldn't work.Has anyone used the stock Tundra Struts and springs, and not upgraded ones?
Yeah I don't know why they are listed like that, they aren't mine obviously.Those aren't pro shocks.![]()
I’m converting mine very soon. Just waiting on my Upper arms to be built. 2010 lx570Does anyone have any more info on what it takes to do this to an LX570? Very interested.
Thanks
Search my posts, look for bushing, or shock mount. I sent pictures of the bushings ICON uses for cruiser and tundra.
Contact Just Differentials for info on Tundra kits.Ive searched and searched for these pic's and not finding em anywhere. Im trying to work out the exact differences between the 200 and the tundra parts but i dont have access to Tundra's here in AU.
If anyone out there in the USA can find me a Kit (LCA's, CV's, Tie rods) im happy to pay for them, and to be shipped etc
I gotcha brotha, DM and let's work it out.Ive searched and searched for these pic's and not finding em anywhere. Im trying to work out the exact differences between the 200 and the tundra parts but i dont have access to Tundra's here in AU.
Nice thanks for sharing, have never had the issues you mention but I've def been eyeing these none the less.So far the ride seems a little more planted. Turning into parking lots with raised driveways used to trigger stability control. Havent heard a beep since installing these.
I would 100% recommend aftermarket heim joint sway bar links to get your geometry back to kosher
Edit: can you share the part number?
Not sure, didn't do anything special and these are the LC links, I think @TexAZ went as far as installing a Tundra link on one side but I could be mistaken. Below are pics of mine, maybe they are "bound" I just haven't had any issues but that doesn't mean one may not develop over time. Edit: the angle of the passenger side link in my photos (top two) seem more "bound" than in the ones above w/ the adjustable links. If you're stock can you take similar photos that compare?BDS 128702 I assume.
If you haven't had issues, can you share what you did with your KDSS/swaybar links? After the Tundra swap, every truck I've seen has the links at horrible, bound-up angles. They may not all fail, but I'd like a clean solution to the issue. The BDS links or something similar looks like a decent solution.
The LCA angle is directly proportional to the amount of lift - more lift = steeper LCA angles. As to the actual degree measurement - someone can surely measure it, but why do you need to know that? And yes, more lift means less down travel available.does anyone know what ballpark the LCA angle should be at(degreee)? pertaining to lift height, preload etc.. I would assume to more angle they have at ride height(sitting) the less down travel available.. @Markuson
From the pics you posted, it looks like you could maybe benefit from swapping the links 180* around the vertical axis so they mount on the outside of the sway/KDSS bar. Assuming there's clearance to do so of course. Mine did clear with both links on the outside of the bar, and the angles are less crappy.
At least on your passenger side link pic, switching it 180* looks to me like it would straighten the link pretty well. What are you seeing that would be worse?That seems like it would make things a lot worse. As I said, I have never had traction control go off, have no clicks or groans, and it's been hammered on for 3 years/30k miles. To me it just logically makes sense that if you lift your truck you should extend your sway bar links to put the sway bar back as close to neutral as possible.
Do any of you with Tundra swap feel you have gotten more down travel? What’s your setup?
