Its not like you hit a certain # and the engine violently blows up,
Agreed.
EGT reads the the temperature of burning gas as it exits the manifold. It does not give you a read on piston crown or valve head temps.
All of which get cooled by a fresh charge of air at close to ambient air temp every cycle. Gas comes in at 25-50c, gas goes out at 850c. Piston temp is somewhere in between.
Pistons in these engines are also cooled by a spray of engine oil which is somewhere sub-100c.
EGT gauge only gives you part of a picture. If you want to know how close to the ragged edge you are, monitor oil temps, cylinder head temps, intake air charge temps, water temps, AFT, and EGT.
At 600c you are leaving a lot of potential on the table.
I had this engine apart after several years service at that MAX temp range, with 250k km on it, it was pristine internally. No indication of running too hot.
I'm not the only one who's happy to run at that sort of temp.
I know of guys who have run at 850c literally for hours at a time on Aussie outback highways where you get ambient temps at high 30s C, unlimited speed limits, and NO corners for hundreds of Km.
At the end of the day, up to you to run what you're comfortable with
There is no way I would run a HZ at such temps.
