- Thread starter
- #41
I don't know if it's a tire issue or maybe the vibration is drive shaft related? Not sure yet.
Some of the recommendations on here are pretty wild, like cracked frame. So yeah just take them with a grain of salt.
I agree with this line of thought. My current opinion is that my panhard bushings allowed the wobble to progress quickly and become violent - but the wobble itself was started by something else. I have Wranger MTR tires that have some age on them, so it wouldn't surprise me if they were at least partially to blame. However, the side-to-side movement of the steering wheel seems to suggest that the gear box may also be worn. Is there a good way to troubleshoot gear box wear without removing it? Maybe have someone turn the wheel with the tires off the ground and pay attention to how far it moves before the tires begin to displace?Frame cracks around the steering box are actually pretty common on 80s. Such a crack won't trigger/start a "death wobble" but the cracking essentially adds looseness to the steering/tracking and allows a small wobble to grow larger so it's relevant when troubleshooting a bad death wobble. The before/after crack repair tracking on my 80 was pretty remarkable and it was easy to feel the crack moving when inspecting it from below while someone turned the wheel back and forth. It's not the first thing I'd check or suspect but it's easy to look for. This isn't very different from a worn steering box in that a worn steering box is not going to introduce wobble but will allow one to worsen.
You can drive one of these (or any solid front axle vehicle) with loose wheel bearings, rod ends, cracked frames, missing dampers, etc. and not have death wobble though these will all make the wobble much worse in most cases. The worst death wobbles I've fixed have stemmed from tire or caster issues. Loose components typically just allow wobbles to grow. If you don't have good caster bumps can introduce wobble and then it can grow from there. etc.
I've adjusted the box before, seemed to help. The truck is drivable as-is but I'd feel better if the steering were tighter. But as you said, something is causing the wobble to start. The new bushings are containing it for now but I need to find what it is before the panhard gets tired of putting up with it..You have to fix the wobble source regardless. Removing gear box slack is nice, will make driving less stressful, etc. but is secondary to the source of the wobble. If your caster is in spec. then I'd suspect the tires myself. If it's a caster issue it will typically only happen after you hit bumps/uneven surfaces or similar so you can possible do some attentive driving to help figure out what introduces the wobble. You can also just have the truck put on an alignment rack to get your numbers, if you haven't already to try to rule caster out of the situation.
If you can reach through the open drivers window and move the steering wheel back and forth while you watch the input and output shafts on the steering box you can get a sense for how much slack there is in the box that way. It is worthwhile to do this test with the wheels pointed straight forward as well as when they are near the end of their turning travel. The gear box can wear more in the middle (straight ahead for the tires) position than on the edges (wheels turned). If the slack in the box is present with the wheels turned then you can tighten the gear box using the adjustment screw. Go easy on this adjustment and be sure to test for binding or lack of return to center, esp. from hard turning angles.
My 275k mile box feels great after a bit of tightening but I feel lucky as not all boxes can be improved this way. I kept tightening a little at a time until I noticed a little binding and then backed off a touch. Don't remember exact adjustments but I'd do it by feel for the most part anyway.
Lifting the front tires can make it easier to detect binding in the box, if you adjust it, but isn't necessary as you can also just monitor return-to-center while driving if you are gradual on your adjustments.
I have caster plates. Can confirm that prior to the plates the 80 was a bit if a loose cannon on the highway. Drives much better now.One more thought here with the disclaimer that I'm not an expert on front-end geometry. If you want to mess around with it, and are willing to risk extra wear on your tires along with other possible risks, you can do things like add a bit more toe-in (etc.) to essentially put the tires under some positive pressure while underway, if that makes sense. This type of trick can mask loose components/etc. in a front-end at least while driving straight and not actively changing the direction of the tires back/forth. Very little, or negative caster and minimal toe can put your tires in a floaty/neutral position which allows them to get wobbly much more easily due to tire out-of-round, imbalance or surface irregularities. Not sure if this info. is helpful but these are some basic ideas to keep in mind as you troubleshoot this.
At the end of the day though you don't want to bandaid things, you want caster/toe in spec, all components tight, wheel slack in spec. and no wobble of course![]()
Land Tank plates installed per instructions, front edge welded to axle bracket. No, I haven't taken to a shop to get any sort of reading. That may be worth doing though just to rule it out.Do you have your current alignment numbers? Have you confirmed that there isn't so much slack in the front end via wheel bearings/etc. that the numbers are accurate? Depending on lift and plates you may still have caster issues.
Also, how were the plates installed? I've heard first hand of looseness being introduced by caster plates until the plates were welded, even though the plates didn't require it (dobinson plates). Not saying this is your issue but you need to understand the whole steering system in order to fix this efficiently (ie. without pointing the parts cannon at it).
I would hope there's not excess slack in my wheel bearings or trunion bearings. They are brand new Koyo bearings installed per FSM less than 4k miles ago. Wheel bearing nuts were torqued to 30 ft-lbs since I have 35's.I doubt you have a problem from the plates then. Yeah, you probably want your alignment numbers though I'd make sure you don't have excess slack anywhere before having someone check your alignment as the numbers may be thrown off by the slack. Steering box slack isn't a problem here btw, I'm thinking more wheel bearings/rod ends/trunions and slack that can allow the wheels to move around inconsistently.
Are you saying that because you think it's related to the wobble issue or are you just saying I need to check the rest of my bushings? The bushings are on the list, the rest of them are sitting in my garage waiting for a free weekend.Check your rear control arm bushings and panhard as well.
I'm suspicious of my steering damper
That's interesting. Why did you remove the dampers on yours? Just curious.
If this ends up being JUST a tire that needs balancing, then I will go on record as saying the 80 series isn't as good as I thought. There has to be something else at play for the truck to shake that violently in a lateral direction. This wasn't vertical shaking like a really bad washboard road - I thought I was going to see steering components start to litter the road behind me. If that's 100% tire then I'm putting on a set of tracks and not looking back.![]()
