- Location
- United States
Located in Snohomish, WA about 1 hour north of Seattle. PRICE IS $2,500
1997 FZJ80 Toyota Landcruiser, 224k on the engine currently. The engine has a significant miss and runs roughly. I believe it has a valve issue (not a head gasket) since there is no water in the oil (or oil in the coolant) and the coolant level is constant. I've only owned this truck a few months and I frankly just have too many projects to tackle it currently.
DOES NOT HAVE FACTORY LOCKERS. This is a NO RUST Washington state truck
This truck has the standard leather seat issues. Does not leak water into the cab. Engine has new OEM Toyota thermostat, alternator belts, radiator hoses, alternator brushes, cap, rotor and radiator cap. I went through and fixed the completely clogged sunroof drains along with stripping the entire interior for deep cleaning.
I have the rear jump seats but they at mismatched, one is tan and the other is the grey color.
This truck runs and drives but should be trailered because of the engine miss. I can deliver within a reasonable distance from Snohomish.
It's missing one front windshield wiper and the rear wiper arm. The front driver side window does not go down, I think it's a switch problem. The factory radio/CD player doesn't work.
Again, this is a truck that is a project/needs work. The head will likely need to come off and be completely reconditioned. I can send a video of it running if you wish, send me a PM
