SOLD 1997 Collector's Edition with Slee 2UZFE V8 Conversion (1 Viewer)
Build Thread:
Builds - BoltRipper's 2-year Overdue Build Thread
VIN: JT3HJ85J1V0188362
This a turn-key 2 owner, impeccably maintained 1997 (12/1997) 80 Series Land Cruiser Collectors Edition with professionally installed 2UZFE 4.7L V8 mated to the Toyota A343 4 speed transmission. Truck has 155,000 miles (48,000 on new motor and transmission) – This has been used as a daily driver since day 1 and has been perfect in every regard.
The truck is 6M1 Dark Emerald Pearl and is Factory Triple Locked. No expense has been spared with this build and Factory Toyota Parts have been utilized exclusively during the build and V8 conversion.
The V8 conversion was done at Slee Offroad in Golden, CO. The build was done with a new short block sourced by Onur from Japan. I also wanted all accessories to be sourced from Toyota and sourced the Starter, Alternator, AC Compressor, Power Steering, Coil Packs and ECU. The heads were completely dissembled, inspected and rebuilt with all new OEM parts. The injectors were cleaned, and flow matched as well. The complete build sheet will be available for review by potential buyers and just about every part is new OEM. You basically have a brand new 2UZFE Motor and Transmission.
The truck had new driveshafts for the conversion and have since been rebuilt again last month. The truck was also geared to 4.88 by Slee.
Thanks also to @Onur for all the help and direction with this build.
Along with the conversion the following will be a basic overview on some of the additions:
New Calipers and Rotors
New Fuel Pump and hoses
Center Differential Switch with 7-PIN Modification
All New Rod Ends and Steering Dampener
New EFI Relay
New Fusible Link
Roof Rack Removal and repaint of roof
Extended Differential Breathers
DEPO HID Headlights
DEPO Tail Lights
RIGID SQ2 Driving Lights w/ Slee Harness
Complete Front Axle Service(s) with new OEM parts including Spindles
Rear Heater Removal
2nd Battery with National Luna Split Charge and Upgraded 200 Amp Solenoid
Complete Dynamat and Dynaline of interior and doors
“D” Bulb Replaced
Matrix 115V Switch with 400W Wagan Pure Sine Inverter
Kenwood DNX771HD w/ Sirius and Backup Camera
Kenwood Sub with Whole Hog Mount
Kenwood X500 Amp
Blue Sea 12V Custom Panel
USB Ports throughout truck
120V Receptacle at driver and rear of vehicle / Inverter
OEM Hand Throttle
Backup Light on bumper
OEM window Seals, Runs and trim throughout
OEM Windshield
OEM Frame to Axle and Axle to caliper soft lines
All new OEM bushings throughout
OEM Rear Axle Rebuild
New OEM outside mirrors
Adjustable Upper rear control arms
Complete OEM parking brake system overhaul
Double Cardan Front Driveshaft
Some Additions:
Scheel-Mann Orthopedic Seats
TrekboxX Alpha system with custom switch plates
Alucab GEN-III Rooftop Tent with crossbar rack
200W Solar System w/ Victron MMPT Controller
OME 2.5” Lift
OME BP-51 Shocks
Firestone Airbags
Dual AGM Batteries
Alpha Overland Rear Bumper with Dual Swingouts
Extreme Air Compressor with chuck outlets on rear bumper wired to dash switch
Slee Custom Skid Plate
Custom mandrel bent exhaust
Cruisin Offroad Sliders
ARB Front Bumper
Warn 9.5XP Winch
Shore Power connections to charge batteries
Toyo ATII tires
ICOM ID-5100 UHF/VHF Radio
Jotto Desk Mount for Tablets
50% Rear Seat Delete Plate
100% Rear Seat Delete Plate
ScanGuage II
Interior Floor LED Lighting
LED Dome and interior lights
Back Bay Customs Tailgate Storage Deck
(2) NOCO Wall Mount Chargers for house and Starting Battery w/ Anderson SB50 Connectors Installed
Wits’ End Anderson SB50 Outlets for Fridge or High Amp External Devices
I have every receipt in individual binders for each year. Extensive maintenance has been done with this truck and the entire log book will be available to potential buyers for their review.
Pricing Structures:
The truck is sold on deposit and is pending final payment.
Asking $59,000 USD As Is - Turn-Key
Without Alu-Cab Tent, Awning and TrekBoxx $53,000 USD ( and I have the never Used 3rd Row if wanted )
Items Not Included:
Yaesu HF Radio unless buyer requests and is General or Armature Extra Class
National Luna Fridge
Truck is available for immediate inspection in Birmingham, Alabama. I will provide any additional photos or videos for potential buyers at their request.
Thank you for your time and best regards,
John~
Congratulations on the sale and to the new owner. That is one amazing, well thought out and executed 80.
Just WOW !!! Absolutely beautiful and I bet the new owner is over the top !! Congratulations
