Build 1994 FZJ80 5.3l and 4L60e swap
Looking great. I got my truck back from Robbie Wednesday. Going to give the mostly-rebuilt engine a good stretch tomorrow and head up to Pawnee Grasslands.
You will be happy with the results.
Robbie is the man when it comes to the 1FZ. Everyone else are mere mortals.
Congrats on the new engine jobber.
that's good! I am glad my old engine is getting some good use! With the rebuilt head and new head gasket, it should be good for many more miles :)
Robbie is the man when it comes to the 1FZ. Everyone else are mere mortals. Congrats on the new engine jobber.
Thx. Robbie gives your skills similar accolades. Must have mentioned you a dozen times as we worked.
It was great. Smooth, strong, pulled great. :cheers:
got more done..
I ordered a replacement shifter cable (trailblazer application) to replace the one I broke doing the install. Got it in and tested and the shifter works great. It lines up with the indicator window just perfectly.
I also managed to get the drive by wire gas pedal installed. That was a bugger.
GM went to a pedal for the 2006 and newer trucks that's just huge. It's also shaped in such a way that getting it to fit the cruiser pedal box is a challenge.
Here's what it looks like:
next to the stock pedal assembly:
here's where it needs to fit:
something like this:
The pedal came with a metal bracket that it sits on when installed in the gm truck. I reworked the bracket a little bit and tied it into one existing hole, and two new holes to arrive at this:
Full throttle:
Released:
This is how close it comes to the steering column joint:
it's a tight fit.
Also mounted the TAC module. This little box takes the signal from pedal and sends it to the electronic throttle body on the motor.
I still have quite a list of things to get done, but there's a light at the end of the tunnel....
I should have it fired in about two weeks.
If your pedal didn't have that bend in it, would you been able to move the whole assembly toward the right? The arm looks like a composite material so it can't be bend I'm guessing.
yes - it's plastic. for whatever reason, gm changed the design for the trucks and wen to this design. Some believe a corvette pedal can be swapped in place for a better fit, but I can't find a single success story where this was done. I am stuck with this pedal or swap out everything (tak, pedal, harness, and reprogram the PCM) to use the older design. It fits, just barely.... and the movement is fine. The only real issue is the pedal sits a little higher than stock.
here's a question for those who have done the vortec swap..
what coolant are you running?
standard green?
toy red?
dexcool?
my 80 had red in it when it was drained to pull the 1FZ. Thinking of getting the asian coolant from napa (basically HOAT G-05 coolant, phosphate free).
nicely done! do you think IF you wanted the pedal lower you could shim out the upper mount points on the tab and move the pedal range lower to the floor (not changing stroke?) kinda tipping the top down?
Another update..
got the Delta Current fan controller mounted and wired up to the fan. Tested it with some 200F water and sure enough, it spun the fans up. They pull a ton of air!
Also dove into the fuel pump wiring. Since the stock arrangement uses a resistor to cut fuel pump voltage under light throttle and then supply full voltage at full throttle, I simply bypassed this and ran a new wire to the pump. The harness is available under the driver's side rear seat to splice in.
Finished building the high pressure and return line and test the fuel system. Pump works, no leaks, but I think the pump is a bit on the loud side. Typical walbro pump.
This is my Rol-Air flaring tool. It does 37 degree JIC/AN single flares.
Buy one here:
http://www.aircraftspruce.com/catalog/topages/flaringtools3.php
I used it to flare the stock fuel supply line (it's 5/16in) and used a tube nut and sleeve to make the connection. The braided line is -06 teflon line and I used the Russell connectors to join everything up.
Engine wiring, radiator upper and lower hoses, exhaust, fluids in the trans and power steering and cooling, and run some cooler lines to the radiator and aux cooler and then I can light it off :)
Getting closer...
was able to get more done in spite of the kids being sick the last 2 weeks and the water pump in my cummins letting go the other night.....
cummins water pump - it's a super easy change, one 10mm wrench and a breaker bar to release the belt is all that's needed. You don't even have to remove the fan :)
The cooling system is ready. I got the hoses plumbed. The top hose is a stock silverado hose cut down and the lower hose is a combination of a stock silverado lower and some off the shelf hose to get a 90 degree bend.
slow progress, but tackling the wiring integration is just around the corner.
I was curious about something: technically, the engine can run (but not drive the vehicle) with the PCM as a stand alone system, correct? You need to integrate with the Toyota dashboard mostly for the gauges, if I understand this correctly.
Did you end up using the Corvette fuel filter with the built in fuel pressure regulator? Cummins h20 pumps are a breeze too bad nothing else is that easy on them, but I do love the CTD though.... Looking good boss
