1994 FZJ-80 rear brake hard lines
MN, USA
I have a ruptured rear brake hard line/tube on my 94 FZJ w/o ABS. It looks like the parts I need are 4736260040 & 4736260050 to replace both brake lines that run along the frame. I imagine I will need all new clamps, etc due to rust. It appears these parts are NLA, but I am hoping I am wrong. Anyone have any leads on these OEM parts? Thanks
MN, USA
Use:
47326-60180
47327-60080
Both are still available from your local Toyota parts professional.
Clamps: 90461-08706 x however many you need.
Thanks for the reply. Just to confirm, are 47326-60180 & 47327-60080 the lines that run along the frame from the front to back? The diagram makes it look to me like those are the lines that run along the rear axle. The red circle in the attached pic the line I ruptured.
OGBeno
11400-17120
Moderator
GOLD Star
Patagonia, Arizona, USA
My bad. I misread and thought you said rear axle.
Yes, those lines are discontinued from Toyota.
You’ll need to make your own lines.
Tucson AZ
@OGBeno This is good to know. I just replaced all the soft lines and many of brake line fittings were mushroomed to the point of not fitting in the new OEM rubber brake lines. If filing off the mushroomed ends doesn't work, I'll be learning a new skill.
