East Alabama
No kidding? - where did you find a Troopy in such great shape? Did you import it?
East Alabama
A close friend imported it for me.
It’s in very good shape. The only rust I have found is surface rust I on the springs.
Is the keymar rear bumper compatible with the 70 swb?
@JMasi I have no idea, but it may fit. I’m going to clean it up and remove it, so it will be for sale soon.
Kaymar does not make a short/mid specific bar. A 75 Series Troopy bar can be modified to fit. The bottom frame brackets need to be cut off and the remaining mounting holes need to be slotted somewhat. Then you end up with this:The easy way is to visit Kaymar's or ARB's home site and search for things that fit your vehicle. But Im pretty sure the rear end of a troopy is the the same as a SWB or MWB. The 7* sries were made that way for a reason.
yep been thereWell today I removed about 5lbs if wires from the interior walls. I removed the wires as I prefer to know what they are all for, so diagnosing any problems will be easier.
Andrew, Can you pull out the third wire from the left and bring it to Rob's when you come back down? I think I can use it on a future project.yep been there View attachment 1980659
