1990 HZJ77 (61 Viewers)
Nope, don't know. Never had to replace keys.
Roof rack prototype. (Sitting on the roof to verify that all of the measurements are spot on). The final version will set nearly flush with the roof top (approximately 1/2" clearance) and will be finished in black to match the rear ladder.
Nice rack, I really like the high lift mount on the back it seams like a less damage prone area than the normal mounting locations.
Do you think you might be cutting it close with only 1/2" clearance? If the rack was used as intended and got loaded up a tad more than it should and driven on a bumpy road (think bringing firewood to camp) I'd be concerned of some rub from flex. I'd go an inch personally.
After all if it's made well enough you can put a chair up there and watch the clouds pass
As with the majority of Rob's designs, the roof rack will be woefully over-engineered so there should be minimal flex. (There will be 8 individual supports). The center portion along the highest part of the roof will clear by slightly more that 1/2" while the front and rear will clear by ~ 1". The beauty of his design will allow for fairly easy adjustment in elevation if necessary. Due to the proximity of the rear ladder, I would assume the bulk of the cargo would be loaded in the rear portion of the rack where the clearance is the greatest. **(Tech content)
**(Non tech content) ... I've been watching clouds pass by for 40+ years and I'm kinda over that. :)
I do however appreciate your thoughts and input.
Nice job on the tech post, Charles. Keep up the good work.
I might suggest rerouting that wiring - I'd find that terribly distracting!
It's my intentions to move the wiring over in front of the passenger seat. :hillbilly:
Yep - perfect.....we're on the same page, then.
View attachment 1209250 Does anyone know if this number is significant for obtaining replacement keys?
Thanks
Hello Charles,
It does not.
There is a little rectangular plate, 25 mm by 8 mm approximately, that comes with the keys. It has a number stamped on it that can be used to cut a key. In theory.
It is better to order a new set (4 or 5 depending on the part number) of cylinders. If your glove box has a lock, the 5 piece set will do. Otherwise, the 4 piece set is good.
One of the To-Do items for my 73, but that is another story.
My two cents.
Juan
@JuanJ ......... Thanks for the info.
I'm told that the number should be like K3784 or R5201.
Like this. Just found my spare.
If you can get one cut, find my ute and smuggle it back on your big kerosene pigeon, you can keep it.
We do serve that region with our kerosene pigeons so when you wake up one morning and your Ute is gone, remember you gave me permission.
You do need another UTE since you foolishly sold the nicest one in the US ...
Anyone know if these floor mats are still available?
Thanks
