For Sale 1990 HZJ73 VX Extremely Clean, Built, Locked (2 Viewers)
SOLD _ 1990 HZJ73 VX Extremely Clean, Built, Locked
SOLD SOLD SOLD
Well Its time to sell my 73. We need something with four doors so its time to sell this obsession.
[/IMG]
[/IMG]
Located in the southern Interior of BC.
This truck was born in Japan and sold through Tokyo Toyota. I have owned the truck for five years and right now it has 206,xxx. I purchased it with 130,xxx so about 15,000 km a year. Its my daily driver from March to October.
This truck came to me stock and I purchased it in Vancouver from a fellow that decided he wanted something bigger - right after Outback Imports brought it in for him.
Exterior:
[/IMG]
[/IMG]
  • Factory PTO
  • Custom Bull bar, bush rails, sliders and rear bumper with swing away tool rack. These have quick fist clamps to hold your shovel axe and pick.
  • Genuine Acrylic headlight guards
  • New grill in 2011 as the original was fading
  • Roof rack built with schedule 40 aluminum tubing mounted with thule rails
  • Limb raisers with stainless cable and marine turn buckles
  • Safari snorkel
  • Rear pintle with 2' ball
  • Cruisin' Offroad 1/4 inch skid plate.
The truck came with factory graphics which I removed and had the sides repainted when I first got it. Last year some one keyed the driver's side so it was resprayed.
Flares are removed annually to clean behind it and cavity sprayed with fluid film. All hardware replaced with stainless. This is an honest rust free truck that has not been winter driven since I owned it.
Nothing was welded to the frame and all armour unbolts.
Windshield is free of cracks and has two very minor chips that are too small to fill
Work lights in the roof rack are all 24v as are the KC highlights
Ladder on the rear is stainless steel.
Monsoon shields have been mounted with stainless and passenger side acrylic has been repaired.
Convex mirrors have been replaced with flat mirrored glass - motors work perfectly.
Genuine rear mud flaps replaced in 2011
Drive Train:
[/IMG]
Stock naturally aspirated 1HZ with five speed. Cruiserland had the valve cover off to set the valves six weeks ago and every valve was within specification. No shims were needed.
Injectors done in 2010
Only genuine fuel and oil filters were used. Comes with my remaining filter stock. I use Shell Rotella.
The rear has the ARB locker and all driveline fluids were done at that time (2010).
Electric hubs have been converted to manual.
Brakes front and rear with ceramic pads and new callipers in 2010.
Timing belt replaced in 2010 as PM.
Rad recored in 2011 as PM.
Complete new rubber hoses, belts, and thermostat in 2011 - toyota red coolant.
Has battery blankets and oil pan heater.
Both front and rear diffs have extended breathers.
Knuckle wiper seals are in good shape.
Suspension:
Old Man Emu Dakar Heavies, shocks and stabilizer. Greaseable shackles are Manafre 3.5" Rear Brake proportioning valve was lifted as well with an aluminum block. Sway bar links were extended.
Wheel's and Tires:
Five matching American Eagle aluminium Baja style 15x8. The spare is a Cooper ST and the main tires are Cooper STT's. They are 33 12.50 r15's and there's about 1/2 inch of tread remaining.
Electrical:
There's a 24-12v Solar converter powering the stereo and an interior fuse block. The stereo works off of ignition but the block provides constant power. There are five 12 volt power sockets available for accessories.
There is a 24v to 12v mil-spec battery charger. This was used to charge a deep cycle battery on a tent trailer.
The ARB compressor is the heavy duty 24volt model.
There is an ignition cut off switch and main power can also be turned off.
Napa Type 27's new in 2010
Stereo:
Over head are 6" JBL's in ported boxes and the factory 4"speakers have also been replaced in the dash.
There's a 10 inch ported Fosgate sub behind the driver's seat powered by an independent amp.
Interior:
Custom rear storage houses the compressor, battery charger, and amp. It also houses air lines from the compressor to each side of the cabin to an air fitting behind each front seat. The storage box uses factory mounting points and the stock rear seat will bolt back in if the unit is removed.
[/IMG]
[/IMG]
The tub and interior panels have be lined with dynamat (very quiet truck) and when the panels were removed the cavities were sprayed with fluid film.
An overhead panel provides mounting points for CB radio (removed) and also the stock altimeter, internal/external temperature gauge from an JDM 61 series.
The dash has a mounting/power block for satellite radio and GPS. This is attached with double sided tape. Radio and GPS not included.
Windows are tinted in the rear (imported this way but are still grey and not purple).
Seats are not collapsed and are not torn as typical. My belt caught the edge of the bolster on the drivers and this has been stiched. Lumbar, and electric bolster work well.
AC blows cold.
I was told by a mudder that this truck looks like it was just imported. I have had people ask me if its new.
Issues:
The cigarette lighter does not work.
The rear main is weeping. I have a new factory seal, new clutch and pressure plate and related bearings ready for when its time to do the job. It does not leave drops in the driveway.
Spares:
I have replacement bulbs, filters and new clutch parts
I have over $30K invested. Offered at $17,500
Link to photos is here: http://photobucket.com/hzj73forsale
I think if we stop bumping this you and I would be able to fight each other over actually buying this in a few years!
Oh and bump! :)
I would guess some Canadian Cruserhead would actually come to their senses and buy the thing in that length of time. :)
PM responded to.
Better to chat ear to ear to work out meet-up logistics. Travelling for work and I'm not always home.
Deposit Pending: Buyer is from out of town. Will update this thread if logistics fall through
Cheers,
John
Congrats. Best of luck with it going through.
and by congrats I mean damn!
It is a good day for at least two Canadians ( the buyer and seller :)) but a lousy day for several Americans. :D
He is completely new so he hasn't known what he is missing. But I already warned him that its an addiction.
He should have started out with a high mileage LJ78. He will be spoiled with a Cruiser that nice. :D
He came to me for advice on what to get and asked for the best for what he wants to do. I don't know if I could do that to someone I wouldn't even buy one of those. Unless it had a kz or kd engine. And still I would rather spend money on a different rig... Maybe even a 80...
You do realize I was just kidding? :)
I am just jealous......
Still for Sale
Haven't heard from buyer. Assuming vehicle hasn't sold.
The truck is being relocated to Vancouver, BC area in 5 Days.
only two more posts to 100
Are you sure? 100 :flipoff2:
  • Back
