- Joined
- Jul 22, 2012
- Threads
- 585
- Messages
- 16,588
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
I wouldn’t do anything like that until you have the body on. You’ll be doing it twice.
Why did you get the dual v-band and not the T4?
Had to spend forever buying a die grinder and the correct bit because the adapter was threaded slightly off. This is using the 85-87 mount and the OEM holes essentially slotted out in the cross member to give some adjustability because the 60 mount bolts are slightly wider apart. Going to join the motor to the transmission tomorrow hopefully to tack in motor mounts. Once drive shaft-pinion angles are set I will be able to set the rest of the axles. going to make some adjustable suspension components on the lathe when the school machine shop opens up. Slow process when you are dumb like me but it is a learning experience haha.
Sourced a solid set of Turbo seats from a RHD rig locally for a decent price. Foam is in good condition just need headrests for the rears. Will have to reupholster these in a blue grey setup if I stick with them still open to finding a set of blue grey for the right price.
Ofc the rears on these foam is mintttttttAah, advance adapters strikes again!
If you find another set, ill take those rear seats off of your hands haha
haha ill shoot you a text, hopefully the ones in texas work outOfc the rears on these foam is minttttttt
Stock ECU and run is essentially all mechanical and just adjust fueling based on AFR. I was going to run it non intercooled. The only reason I’m going to run an intercooler is because it’s a hell of a lot easier to set everything up now before paint etc than after. Basically I graduate w my bachelors in March and will start working but next fall I will be starting grad school so this will be my most opportune time to set up all the infrastructure now versus going backward and setting up later.I would recommend starting non-intercooled and just run 5-7lbs and see how it is before you turn it up. Mine is a little bit bigger tire and softer suspension and gets really stupid at high rpm in boost; yours should be a little more drivable but still. Start small.
What are your plans for ECU?
This is not so much about power as it isI would recommend starting non-intercooled and just run 5-7lbs and see how it is before you turn it up. Mine is a little bit bigger tire and softer suspension and gets really stupid at high rpm in boost; yours should be a little more drivable but still. Start small.
My goal is to be able to drive it one handed at 100 suspension wise. Besides waste gate and BOV my hp hard limits will likely be tires also because I want it to be relatively stock looking lift and tire wiseI would recommend starting non-intercooled and just run 5-7lbs and see how it is before you turn it up. Mine is a little bit bigger tire and softer suspension and gets really stupid at high rpm in boost; yours should be a little more drivable but still. Start small.
There is a guy in Vancouver that does everyone’s LS around here and he is good both NA and turbo. You are right about the intercooler I will never get to the point of my intake temp being an issue really with the relatively low boost. This will never see over 1 bar or really even close otherwise everything and their mother would break hahahaDo you already have a good local tuner who is experienced with HP Tuners? Or are you planning on tuning yourself?
if you can afford to go Holley I would.
Depending on which ECU you have some of the early ones will only recognize 1 bar of Map sensor.
What are your plans for injectors, FPR, pump, etc
On the intercooler topic, just saying I have plenty of non-intercooled data from my 4.8 BMW on pump gas an Flex, under 15lbs IATS were under 200f and that was racing it.
I don’t think it’s worth the fabrication for a typical Land Cruiser
Fuel related stuff I was looking at this morning but not in a crazy rush to figure out. I do have a DBC L59 5.3 in the shop for my 40 build I could swap intakes and that would probably take care of any fuel rail anything. L59 injectors and fuel rails would probably be enough to start the party but need to do more researchDo you already have a good local tuner who is experienced with HP Tuners? Or are you planning on tuning yourself?
Gotcha. I 1000% plan on having to build both a 5.3 and a 4l60 down the road.If you’re doing stock ECU make sure you go AEM for your wideband. They’re the only ones that are any good.
PQY on amazon are a good boost reference FPR for about $30. I’ve used about a dozen of them. Get yourself a set of PAC 1218 valve springs as well. I would just run the stock cam at first and see how you like it.
450lph pump and and the stock fuel lines should be fine for your goals
Welllllll when you say you have never seen anyone break a transfercase that changes the plans for phase 2. There are 3 routes this ends up.I have never seen anyone break a split case from anything other then improper assembly or letting it run dry.
If you have the early fuel rails with the
built-in regulator those work perfectly as well.
You shouldn’t need to build an engine for what you’re doing, just valve springs. Put the money towards a torque converter.
