I'm looking for a fuel cut vacuum switch. Sits on the drives side fender well, near the washer tank. It has one vacuum line and one wire connected to it. The vacuum goes to the carb insulator plate.
Pretty sure I have one. I can check and get back to you shortly.I'm looking for a fuel cut vacuum switch. Sits on the drives side fender well, near the washer tank. It has one vacuum line and one wire connected to it. The vacuum goes to the carb insulator plate.
Thank you, I appreciate your help. While your checking would you see if you have a headlamp washer fluid tank available?Pretty sure I have one. I can check and get back to you shortly.
I do have it. It only has one crack towards the top section. Can email you pics: SigfridsAndSons@gmail.comHVAC Panel Bezel?
I do have some door cards but the vinyl is cracked on the top of them in areas. Radio speaker covers are missing, too.Looking for front and rear door cards in grey...do you have any? Also looking for grey dash pad that’s not cracked... shipping to 85296
PM SentOuter vent control valve, the electric valve bolted to the charcoal cannister. Also looking for a green vtv (on the carb) and the two outer dash vents, the ones that close.
Price + shipping to 95672?
Sure do. Will PM you.Looking for an 87 or 87 pedal bucket to swap an H55F into my 62. Still have one?
Thanks.
I think I have one left. Do you need the whole thing? Upper and lower? Cushion, frame and all? What kind of condition are you after? What color?Rear bench seat available?
Best,
Chris
I have a good lift gate butthhIs the tailgate and lift gate available?
PM SentIs the tailgate and lift gate available?
I believe that color is 411 beige. 416 is Dune Beige. As in what I painted my truck which used to be beige.![]()
Parting out a 1986 Toyota Land Cruiser FJ60
100+ photos here:
- Dune Beige exterior
- Brown interior
- Door cards are excellent
- Interior seats in good shape
- Good center console
- Lots of great interior parts
https://sigfridsandsons.com/product/1986-toyota-land-cruiser-fj60-dune-beige-all-original/
Cool.I believe that color is 411 beige. 416 is Dune Beige. As in what I painted my truck which used to be beige.
