1986 4Runner Refresh (2 Viewers)
I finally started what will be a long and slow process, body work. The 4Runner had been in several slow speed accidents prior to me buying it. One was from parking on an incline without it in gear or the emergency brake set. It rolled back with the DS door open. This bent the door backwards and put a mild crinkle of the body behind the door. The door check was badly damaged at the A-pillar. and the door hinges pulled away from the body. The DS fender was damaged in this accident. The core support is a little damaged as well as the hood and wiper valence. I don't know how that happened, but I think another slow speed front end accident. Another slow speed accident put a dent in the PS fender.
A new door was installed on the badly bent door hinges before I bought it. It required shims on the door side of the hinge to make the door work. Tony had found a clean hood, wiper valence and DS fender before I bought it from him. I found some good hinges over a year ago. I also cut out a clean radiator core support from a donor just in case. So I have almost everything to piece together a mostly clean body and I'm hoping to hammer/dolly/body filler will fix the rest.
The door leaked air like a sieve on my drive from Sacramento and I did a temporary fix of the hinges by beating them into place. This helped, but far from perfect. A lot of the air leak could be fixed by pulling the vent window shut, but still plenty elsewhere.
I did some measurements and I think the slightly bent core support will work. I'm thankful for that as it would be a big job to replace. Here is the slight crinkle in the core support.
To double check this I decided to replace the door hinges, align the door and test fit the clean fender and look at the body gaps. I've been avoiding this because I've heard it is a bear to realign the door after replacing hinges. What I learned is yes, it is a bear but only if doing it by yourself. As soon as the Mrs was available I was able to easily align the door. I used digital calipers to compare the body gaps on the PS door and came within a 0.5mm all the way around. I struggled for an hour by myself, but with the help of the Mrs it took about 20 minutes. I guess I needed my big boy britches for avoiding what in the end was a simple job with the bonus that the shims are gone. The wind noise is almost all gone. What is weird is all the wind noise from the vent window is gone. I guess the old hinges warped the door just enough to keep that vent window from sealing completely. I'm thinking that some new weatherstripping will solve any residual noise. I'm very happy about this.
On the door check, I think I am just going to make an L bracket to fix it and rosette weld it in place. I explored this area in junkyards and it is very complicated back there. I'd have to cut an access hole to go back to OEM. I hope this works. I'm open to better ideas.
I temporarily mounted my donor fender and the body gaps look OK. I need to play a little more and double check the radiator core support measurements. I am hopeful. I ran out of daylight to test fit the wiper valence and hood. I'll test fit those this weekend to confirm that core support doesn't need to be replaced. I'll tackle the DS body damage next. It maybe a simple as inflating a ball back there to fix most of the damage. You can barely see the dent in this picture.
Should be simple. :lol:
Then I'll need to repair the crease/dent in the PS fender. I've thought about just finding a clean one, but it may be fun to see what I can do with this one. This photo makes it look worse than it is.
295c8251-7ea7-40ea-87c6-d1b3e117cd42-jpg.1374285
I'm at a cross roads. I don't have access to an enclosed garage to really start painting. I can do the body work and do a quick primer/rattle can top coat out side. I'm trying to decide if I should paint my good panels to ~match now for instant gratification or will this bite me in the butt when I can paint it for real. For now I'm just test mounting my clean panels to check body lines and the like. At least that is going well. I could run with the clean panels, but then I'd be sporting a tri-color 4runner. I get courtesy stopped enough as it is, mismatched panels will up the ante. Either way it is good to start making some progress.
My $.02
Do not paint the whole truck!
Paint the panels with single stage paint if you can and match what's on the truck.
Well, has it been repainted before?
A full paint job is a slippery slope!
My $.02
Never repainted, but showing bare metal in places. I know it is a slippery slope. How slippery? I guess I'll find out.
:lol:
:lol:
It sure is. The paint on my ‘87 is good in some places, not so good in others. What’s a person to do? I could touch it up and buff most of it out, but a halfway decent paint job would look better that it does now.
I am contemplating pulling my doors and putting on QD hinges to run doorless and topless in the summer, maybe tube doors so I don’t fall out:hillbilly:
:lol:
My youngest daughter and you would get along great. She is on my ass to do the same.
Yeah, if I jump on one of the new CanBack tops, I’d love to run the safari top with the sides zipped off, tube/no doors, and the moonroof glass pulled off:smokin:
I just have to rig up a lift in the garage for removal and storage of the hard top.
I’m following the CanBack revival closely. I truly appreciate you keeping us informed. I’m in when it happens.
Keeping it the same color helps limit the chaos.
You really should have a shop space to work in, just to help keep track of parts and hardware....
My truck was down over a month, pushing hard evenings and weekends. I am lucky to have a close friend who does body work for a living and also has a hobby shop/paint booth. I was in his space and he was helping, but had to keep it moving.
Its all about the prep work!
Four years later, I see very clearly where I missed spots prepping it.
A few new things done.
The clutch pedal has been squeaky since I picked up the 4Runner. Use to only happen in cold weather. It evolved into all the time. I tried squirting in some lithium grease and that only really made a mess. I dismantled the clutch fork pin and found the little plastic bushing was worn. Being a cheap bastard I went to Ace and picked up a delrin spacer that had the correct inner diameter for the fork pin. I had the machine the OD to fit. Since I don't have access to a lathe or mill, machining was me hand filling about 1.2 mm. It was a pain and worse it didn't work. :doh:
I then removed the clutch pedal, took it apart, cleaned and greased it all up. Installed and no more squeak. :bounce:
While filling up with gas a few weeks ago on a windy day I became irritated because the wind blew my gas cap off the roof twice. There is no gas cap retainer like most newer cars. While at the Pull A Part I harvested one a mid 90's Camry. I cut off the unnecessary bits and epoxied some rare earth magnets on. No more falling gas gaps.
Lastly, a week or so ago I was headed to work and about a block from the house it sounded like my little 22RE grew a supercharger overnight. Not the power, just the noise. I went home and drove the Land Cruiser. I was having a heck of a job finding exactly where the noise was coming from except from the front of the engine. A friend came over this past weekend to drink a bit and together we found it was the power steering idle pulley. I replaced the bearing and all is good. FYI, don't be like me and pay attention to how the pulley goes on. :doh:
I hate squeaking pedals. Did you look into getting the proper bushing from Toyota? I just bought the ones for my auto shifter and they were $3. I’m wondering how long the grease job will keep away the squeak?
I found your next project: clean the inside of your fuel door!
I could have ordered the bushing from Toyota, but it was Sunday and I wanted it done then. It kept me out of trouble for an afternoon. :lol: The actual clutch pedal pivot bushing was still in good shape, just dirty. It will be squeak free or not, if it comes back I'll do it again I guess.
Don't judge my patina. :lol:
Nice 4Runner man! If you ever need an extra hand or wanna shoot the s*** let me know! Always happy to help.
Oh and also - on the paint job. A couple years back I backed into a landscaper's truck who was working at my parents. I was working at a dealership at the time and an accident would get me fired.
So I told the guy if he gave me a week I would fix his truck and completely re-paint it - and me and a buddy did. It's not HORRIBLE. But it's not fun either. Prep is the key, and spraying is easy. Imagine two 20 year olds re-painting a truck for the first time. It went by pretty slow. The truck didn't come out too bad though! The guy who owned it loved the new paint so much that when he was rear-ended again and got a different color bed he called me up to ask who painted the truck last and if they could do it again!
Long story short, it's not the worst thing I've done on a car. But it took the two of us a complete week to sand, prep and paint the truck after school, so prepare for the time aspect of the paint job first. I think in total I paid $700 in materials to do his whole truck with some left over. Painting it the same color definitely does make it easier and limits the heartache.
On a side note though - my buddy who helped me is planning on re-painting his car at some point in my garage. If he gets it all setup like a paint booth (which is what we did the first time) you're more than welcome to come and spray it there.
@GeoRoss did you ever remove a leaf from the rear spring pack? Got pictures?
I did. I took them off and realized I didn't have a good plan to take the main springs apart. I thought they would just come apart but they appear to be riveted or pinned in some way with the retainer. I was in a rush so I just removed the lower overload spring. It only lowered the rear about 1/2", but the ride is now much less harsh. I'm not really liking the rake. I don't want to raise the front with ball joint spacers. I may see if cranking the torsion bars 1/2-3/4" will help with the stance or just grinding off the pin and removing the spring ARB said to remove. I've just been sitting on my hands sadly with decision paralysis. I'll post up some pictures later.
I'm dealing with a fuel pump replacement f@ck up. I twisted the high pressure hard line to the fuel pump bracket. The replacement one I ordered may of come from a 17gallon tank and will not fit my 14 gallon tank. I'm due a smog check this month to renew registration.:bang:
bummer on the fuel tank issues. Isn’t trying to keep old trucks on the road as DDs great?
Whenever you get a chance to post a picture would be awesome. My stock rears are pretty beat and I’ve order some CS009r springs, but I only want about 2” of lift from where I am now. Like you, I don’t want to lift the front any as it clears my 33s very well and I’d like to keep the IFS alive as long as possible.
I figure I’ll have to swap some stock leaves into the OME pack to get exactly what I’m looking for, but the CS009r springs will be a good starting point.
Hey I know it's been a while for this thread, I was wondering how the door panels have held up? Have you done anything else to the 4Runner?
