- Thread starter
- #21
I used cruiser Outfitters for my knuckle kit. Flawless install with no hic ups.My new General Grabber ATX 31x10.5x15 arrived today. I'll drop it off to be mounted tomorrow. I look forward to ordering the other 4 to go on the truck. Also will order the wheel bearings and knuckle rebuild kits this week for when I get home after this next work trip. Any suggestions for where to order the parts from? I've looked at Marlin and Cool cruisers sites and have order from cool cruisers before. Any other input welcome for sourcing.![]()
I need to do this too. Thanks for posting that video! I was certain I would break that crank handle.Lots of things done today. On the way to work on my truck I stopped and picked up my new spare tire:
The first thing I did when I started working on the truck today was to pull apart the passenger door panel and lubricate all the moving parts of the window regulator and to lube the slides. The previous post I mentioned the door handle and that towel trick was amazing. I watched the video and was skeptical at best but the moment I did it the clip popped right now. I need to replace the rubber tracks and the rubber seal scraper on the door panel but at least i can crank the window easily and smoothly now.
The sensor that’s hanging off the pcv hardline below and to the right of the carb often looses its connection. Reconnect it w/ bicycle brake line or something stout and heat resistant (I had a worn out choke cable) and you might have a fan again. Attach it to the most often broken line that is in the sheath w/ the fuel cut solenoid. That’s the other end you might be having trouble finding. I can take a photo of mine if you need guidance.Working on the carb cooling fan this afternoon.
1. The relay located between the wiper relay and the turn signal flashed is I believe the cooling fan relay and it does click when the key is turned on or off.
2. All fuses seem to be good
3. The white wire with black stripe that goes to the cooling fan is continuous to ground with a hot engine bay.
-guessing this means the thermo switch is working but will pop the green connector and test it directly.
Only thing missing seems to be 12v on the blue wire with red stripe that would go to the fan.
Anything else to check?
Idk about all that grease you packed in there. That seems pretty excessive. Def not a step I took or remember reading.... but I am getting old and tend to be horribly distracted by a child most days so I could be wrong.
