- Thread starter
- #261
Throttle linkage bracket sbc
Again I am trying to save a dollar where I can so I whipped up a simple throttle cable bracket to work with my generic lokar cable. It is nothing special but here is a pic incase anyone wants to mimic. It needs to be cleaned up and painted still.
Also my pedal mod needed to be extended about a 1/4" to half an inch to increase the arc when pushed. My pedal maxes out and my throttle is about 3/16" from wide open. Easy fix.
Thats right!! Brake Master. Thanks angurus
I dont know if all manifolds are the same but my spacing was 3.25" between the mounting holes, the washer (cable mounting spot) is straight above the second mounting bolt and is approx. 3.5" above the lower mounting plate. The angle of the bracket mounts to the manifold in kind of a 45 degree angle and the round stock is parallel with the mounting bracket. I believe it will clear the air filter fine since it is all lower than the Distributor.....
