Well Jim, you did do my carb, right?
Is this Canadian for "Jim can I bring my rig to your shop please"![]()
Dust on the HOOD! Come on man.
Really like your color choice. Body color roll cage is![]()
What type of distributor is on the engine?
Beautiful work!
Beautiful rig, love the colour. Can I drop mine off to you to get the tub redone...If so, I’ll throw the steering column and be there in a Jiffy.
My gut reaction is that it’s a timing issue.
Have you tried hooking the vacuum advance to a ported vacuum source? That’s where it would be connected if I wasn’t a DUI. I’m throwing it out there... but I’ll be honest, I know nothing about DUI. I have been messing around with my points distributor(s) in my 40 for many years. I had the last 10.25:1 SBC running well on 87 octane for 21 years. The current 8.5:1 SBC loves it too.
If you have the original distributor, I’d throw it in, check & double check it’s fully seated into the oil pump, and go for a spin. If it solves the issue, it’ll narrow down the source of the problem. Alternatively, retard the timing a degree and see if it changed the symptoms.
The rubber damped timing gear is known to fail in old age, allowing the outer ring of the cam gear to walk around, effectively retarding cam timing. If it is bad enough, the symptoms will be low compression, low power, weak idle.
HTH!
There was also this
Maybe some progress, maybe not...
I re-researched my vacuum connections and found that I had the carb diaphram vacuum tube connected to the vacuum port on the front of the carb base. I noticed that that diaphram was working its linkage on the 2ndary throttle when vacuum varied, so it was working. I pulled my "Evaporative Emission Control Device" and noted one hose connected to the carb base port, and the diaphram has a separate connection to the device. So in my re-assembly I may have assumed attaching the carb port to the carb diaphram was an acceptable deletion of that device. I seem to remember thats how they are plumbed on typical generic asian (not Aisin) carbs. I will likely rebuild/restore the EECV once the motor is running just right, I believe its function is really to manage the purging and venting of the charcoal canister and gas tank. I have all the pieces. I really want to get the motor running properly before adding that back into the troubleshooting mix.
In any case, I plugged off the carb base port and disconnected the 2ndary carb diaphram. Connected the dizzy vacuum to the intake manifold along with the manifold vacuum gauge. Plugged the new carb vacuum tube as DUI insists the distributor wants intake vacuum signal, not port vacuum signal. (interesting side note here, in my experimentation with vacuum plumbing I notice when the distributor vacuum advance is connected to carb port vacuum, and timed to 13degrees, when I then change the dissy vacuum source to the intake I have to adjust the distributor ~4 degrees to get it back to 13 degrees at idle.)
They just salted the roads here, so just warming up in the driveway and doing some gentledonuts around the lot in the snow to test the differentials and transfer case. It pops in the exhaust on throttle-off still. Starts perfect and idles smooth if lean as noted above. Cooling system, heaters, radio, wipers, lights all work perfect!
