1968 FJ40 Jolene (2 Viewers)
Stuart, Virginia
I decided to organize my ongoing project progress as a Build instead of scattering threads randomly across the tech section.
I’m going to have to pull a Star Wars … and start a bit after the middle. This is the story of Jolene, a 1968 FJ40 I acquired in 2021. She was well used and well loved, with typical aging and use issues.
Drove and enjoyed Jolene a lot. Came home on 4 cylinders one afternoon. Blown head gasket. Decided to do an engine and transmission update and redo the truck more to my preferences while things were apart. Had so much fun driving it around but it needed attention in areas, let’s get ‘er done.
The pictures below show Jolene the 1968 FJ40 right after arriving home in the Virginia mountain foothills…
Having introduced Jolene and the general need to pull and replace the engine and transmission and address other issues I want to document my most recent work now, and backfill the the older work as time allows. So sequence might be an issue … hence the Star Wars reference.
I’ll try to encapsulate project steps individually.
Install Restored Heater Box
Earlier I documented my adventures in restoring the original heater box. It was a rusty mess, full of mouse nests, but now it is restored and ready for installation.
I rejuvenated the blower duct connector seen attached to the heater box. The old rubber was beginning to crack in places, but I cleaned the connector with 90% isopropyl alcohol, and then treated it with spray rubber sealant several times over several days, allowing appropriate intervals to cure. It seemed to do the trick.
Sequence of operations matters on this task. If you do some steps out of order, you may not have room to perform other remaining steps.
Before I could begin to install the heater box, I needed to replace the old and torn defrost duct hoses that run from the sides of the heater box behind the dash to the base of the windshield.
Yes, I did have to go get the other end of the hose that was still stuck up under the dash. The original ones were pretty far gone.
I got two of these defrost duct hoses from SOR. They were a bit pricey, but they are extremely well-made, and precisely fit the duct connectors under the dash and at the heater.
Before installing any of the heater box, I highly recommend connecting the defrost duct hoses behind the dash first. It is a snug fit, but these hoses are just the right size. I was able to tuck the bottom hanging duct hose ends out of the way while we installed the heater box.
At this point, the sequence of steps to follow is:
1. Mount the heater box with loose screws leaving wobble room.
2. Slide the gasket from the heater box to the blower duct onto the blower duct body.
3. Tighten heater box bolts and fasten the 90° defrost duct elbows to each side of the heater box body.
4. Connect the coolant hoses from the heater box to the firewall hose inlets.
Mount the heater box with loose screws, leaving wobble room
Slide the big square gasket from the heater box onto the blower duct body.
You can see things are starting to get crowded.
Use a socket with a long extension to tighten the left 2 heater box bolts. A ratcheting box wrench is recommended to tighten the right 2 bolts for clearance reasons.
Now it is time to connect the defrost duct hose elbows on either side of the heater box. Remember to put a clamp on first.
I used the old hardened coolant hoses that I removed from the old heater box and duplicated them with fresh new flexible hoses.
I found it a good idea to do a mock up of the connection first to ensure I was placing clamps where I could be able to tighten them once the hose was connected to the inlet.
I found out it is so much easier to do these hose connections with a little help. 90 seconds submerged inside a mug of hot water from the Keurig machine does a great job of softening and expanding the hose end.
Then squeeze a couple of drops of dishwashing liquid on your finger, and put a tiny coat inside the open heater hose end, it makes the snug connection to the firewall hose outlets much easier, especially in the limited space.
Once fully connected, ensure there are no bends or kinks in the coolant hoses. I made the inside hose a little too long, and had to remove it and trim it down to the correct length, and get rid of the slight kink in the hose.
Once you have the hoses seated on the firewall inlet tubes, you will realize the importance of proper clamp orientation when you go to tighten them.
… And that completes the 1968 FJ40 restored heater box installation.
Transmission Hump Cover
Jolene’s interior floor had been covered in spray bed liner. I chose to go back to the original paint. It took a whole lot of grinding and wet sanding to take the hump back to metal. It needed to look uniformly good with the repainted blue floor pan up front. Usual paint sequence, surface prep, wipe, prime, wet sanding, wipe, top coats.
80% done on the prep
Now prime:
Top coats:
Jolene, a 1968 model, originally had column shift. One of the previous owners converted to floor shift. They cut a square out of the transmission hump cover and added a cover plate for the floor shift cavity. The cover plate needed love too.
I had a local welding shop fab a replacement:
Some grinding and paint on the shifter cover. The shifter cover finish convinced me to take the tunnel cover all the way back to metal and repaint, as seen in the previous photos.
It was time to put the new shifter cover on the repainted transmission tunnel cover:
If the hole looks off center, it’s because Toyota made it that way. It’s 11 inches from the drivers side of the tunnel cover to the hole center, and 9 inches from the passenger side of the tunnel cover to the hole center. Just how it is. Jolene being a 68 model, still has the manifold vacuum shift to 4WD, so no second selector at the tunnel.
Time to put on fresh gaskets between tunnel and tub pan. Used this kit from SOR:
First I did a test fit to see how good the gasket set was. I give it 5/5 stars for quality and accuracy. Secured the pieces (with backing intact) to the tunnel with painter’s tape. Helped to sort out the pieces and figure out where they were gonna go anyway.
It was a really good fit. From here I untaped one piece at a time and installed them around the perimeter. The gasket adhesive was good, but I added a little bead of clear rubber cement to the edges before attaching each piece. To encourage the gasket pieces to follow the curvy surfaces faithfully, I used a butt load of gem clips to hold the gaskets secure and not lift up from the pan edge.
FWIW the gasket holes lined exactly up with the pan. Nice.
Here is the gasketed tunnel after the adhesive cured and the gem clips were removed. The next morning the clip imprints in the foam rubber had pushed back up flush.
Next step is to renovate the rear heater hoses that run along the passenger side of the tunnel cover, and then install the cover.
Oh, the SOR tunnel gasket kit also came with a complete bolt and shoulder washer set for the tunnel cover, which was also nice.
I think most of the build threads start out like this. It isn't until a lot of work happens that we are like you know what this would be a good build thread. n
This is Jolene ready to receive her new tunnel cover.
The new tunnel cover is on. It was a whole lot harder putting the M8 bolts back in then it was removing them to remove the tunnel cover originally.
Definitely take your time. It was useful to use a Phillips screwdriver to help align the tunnel cover holes with the nut wells in the floor pan.
I will leave installing the gearshift and the rubber shift boot until next time.
You need one of these before installing the fuel tank... What have you done to your Land Cruiser this week? - https://forum.ih8mud.com/threads/what-have-you-done-to-your-land-cruiser-this-week.255593/page-1974#post-15820528
