I’m keeping the original drivetrain, 73k original miles but I’m having a hard time finding a rebuilt OEM carb or a rebuild kit, should I convert to the Weber double barrel.. all suggestions are much appreciated
Thank you. This will fit the 1967 3.9 f motor?Aftermarket 2F / 1.5F Carburetor for Land Cruiser FJ40 FJ60 - Made in Japan
High quality aftermarket 2F / 1.5F carburetor for desmogged applications. Same as OEM part # 21100-61012. Made by Fuji Japan. Notes: If your vehicle is 1976 or newer and your vehicle is registered in California or other areas with smog check requirements, you cannot use this carburetor. We...www.cityracerllc.com
Thank you !When I bought my 67 it came without a carb. I procured the correct one though Marks offroad. Once I received it and bolted it on (primed it of course) the beastie fired right up and purred like a kitten. Now keep in mind you get what you pay for, and not having to fiddle fart around with the carb is a relief.
Kevo
I just sent mine from my 1962 fj40 to redline Landcruiser’s in Colorado. He’s rebuilding it for around $300.I’m keeping the original drivetrain, 73k original miles but I’m having a hard time finding a rebuilt OEM carb or a rebuild kit, should I convert to the Weber double barrel.. all suggestions are much appreciated
