I have considered rear steer... but wouldn't making the 14b a steer axle be stronger than running a 60 upside down?
Your 60's rear frame (and body) is too wide to do rear steer.
Bypass the air shocks, you'll be happier with coilovers.
FOA's are the most cost effective.
Shaved 14 bolt
shaved the bottom bolt off? how does the cover seal at the bottom now? sounds interesting, i haven't heard of anyone shaving one that much before
the ring and pinion would be stronger but the rest of the conversion pretty much just uses D60 parts.....and you wouldn't be running the 60 upside down either- if you had a driver side drop in the front it would be passenger side in the rear
figured if he would go to the trouble of rear steer and 4-link etc he would cut the rear frame off and tube the rear out, get a fuel cell and clearance the fenders
some big diameter air shocks might not be too bad if you still have leafs on the front to help with the body roll
Why did you buy a bodied rig when a buggy seems to be what you wanted?
I guess I should figure out how I am gonna clearance and or dove tail the rear and still keep a back seat and a place for my 2 pane tanks and bee.. er uh... water and soda cooler.
