For Sale 12-20-23 UPDATE Engine External Parts 3FE from 91-92 FJ80 - alt, PS pump, starter, EFI, Sensors Everything
Status
Not open for further replies.
Deathvalleypaul
FJ80 Collector
Near Pasadena CA
  1. 80 Series
Los Angeles area - I just pulled and sold the head off the engine. Everything else is still here
PS pump with pulley $60.
Alternator (NOT HIGH OUTPUT) $500.
Good Used Starter $60
Freshly rebuilt starter Sept 2022 $100
EFI Manifold
Exhaust manifolds.
Valve Cover - Clean and not multiple coats of chipped paint.
Valve Train, Pushrods,
Themostat housing,
Sensors,
Pulleys
Working Smog Pump and hoses.
AC Compressor and lines and parts.
ETC ETC ETC
I also have the car here for other parts
Hello I’m looking for the down pipes from the manifold to the [ Y ] 3fe and a birfield for a 91 Fj80
Down pipes are available.
I highly suggest buying a NEW birfield as compared to putting a used one on with 200 -300 thousand miles on it.
I do have a couple here but they have some surface wear as well as not having tight cages. Good for spares but not worth the effort required to change them and then change them again.
Consider Security Check - https://www.carid.com/1991-toyota-land-cruiser-performance-driveline-axles/g2-axle-gear-birfield-cv-joint-692971456.html $179 built by G-2. Used Birfields are $100 to $125, Labor time at home is about 6-8 hours, parts kit for installation about $60-$80, so why put in a used one.
repost
Is yours a 91 or is it a 92? They used pumps with different reservoir sizes, one is short and other is tall and they do not interchange. I have a 91 and if this is the year you need will send you a picture to be sure.
I looked the pump over and I am not pleased with it enough to sell it. It appears to have some cracks near the base of the reservoir and I am very fussy about what I sell to others, or use myself.
My apologies, but your needs come first when it comes to selling used parts.
Many more parts now available for 3FE engines
How much for the valve cover? Shipped to 20676. Also do you happen to have an air box lid 91 LC
The valve cover is $35. Condition is good.
I also hsve the lid for 91 and 92 in good condition. It is $40.
My prices are low but shipping has to be calculated. I estimate shipping at $70 to 85$.
See your personal message
I just added all the under hood parts from another 3FE 80 series so I have a good stock including down pipes.
Yes, I drove it and it ran great. By sensor, do you mean the MAF itself, or a sensor?
Hmmm… mine has been idling rough after warming up and was told to try replacing the MAF. So, I’m guessing just the MAF itself.
Status
