100's with aftermarket wheels? (1 Viewer)
I'm running Method 313 in the +25 offset. The hub bolts barely contact the wheel which required me to run a 6mm spacer for clearance.
Those wheels look really good. Compliments the whole look of the LC. Do you have some close up or detailed pics of the wheel center bore to the spacer/flange bolts/nuts? I looked up the specs of 313 from method’s website and it says it has a backspacing of 6.20 inches and hub bore of 110.5mm. I wonder if that is the reason why you had to run a 6mm spacer. Still understanding backspacing spec at this point. The 18s 304s that I like has 6” backspacing and 116.5mm hub bore.
I got wheels! Got trd tundra wheels off a guy who bought a brand new 2021. Had em powdercoated. I wanted a single digit shine to be more like a pvd coating. Added black lugs...I’m pretty happy. Ordered 1.25 bora spacers to clear the caps and improve stance. I haven’t sprayed my caps yet and I’ll probably spray my hub centers when I put on the spacers. Might leave caps off
Those are probably my least favorite Tundra wheels before they've been powder coated, and one of my favorite Tundra wheels after they've been powder coated. Looks great!
That’s truth the two tone and polished faces creates some sharp edges that I just didn’t like. Almost bitched out on having em coated. Another dudes bronze chrome results put me over the top
Yea, it really dates the wheels and I don't like newer wheels on older vehicles (although I do have Rock Warriors on my 2006 LX so like everyone else on the internet, I'm a huge hypocrite). I think I know exactly which bronze wheels you're talking about. Those are really what sold me on the TRD wheels as well. I saw you waffling around a bit on which direction to go and I think they look great on your rig.
The center bore on the methods is correct for the 100 series. The problem is the lip that the center caps snap onto, that’s what was contacting the flange bolts which required a 6mm spacer.
Appreciate the insight and photos @HoustonFj80. I reached out to method thru email and they said the 313s on 110.5mm bore use a cap retention feature (lip). The 304s hub bore is 116.5mm so it will clear the flange bolts w/o the use of a wheel spacer. They do however mentioned that I would have to get a different center cap part to fit on the front hub flange: Center Cap | Push Through | 306 - https://www.methodracewheels.com/collections/center-caps/products/center-cap-1922?variant=8044005916708
Are these basically the same as the new RR7-H wheels? I’m assuming 17x8.5 with a 0 offset? Tire size? Lift? Looks awesome.
There’sa slight difference between the two. I believe both are still out. Yes mine is 17x8.5 with 0 offset. Tire size is 295/ 75/17. Lift is a Dobinsons 1.5” lift
Did you ever run those wheels without a lift? The AHC on my 06’ LX is still running strong, been wanting to drop down to 17” wheels for a while, tire size has been the big question though.
