cruiserpatch
Supporting Vendor
- Joined
- Nov 24, 2020
- Threads
- 115
- Messages
- 1,113
- Location
- Atlanta, Georgia
- Website
- www.cruiserpatch.com
Howdy!
It's come to my attention thanks to the feedback from some Diesel 100 owners that the AHC HDJ100 torsion bars have been delisted. I'd like to help get some options back on the market for those wishing to upgrade or restore their Diesel 100 Series Land Cruisers (and in the future, for all us petrol owners once our bars go DISCO).
We've just filled our first pre-order of 10x sets of 27mm, 1160mm long UZJ100 w/ AHC 'Cruiser Patch' torsion bars.
We're also currently shipping our first run of 29.5mm, 1160mm long UZJ100 'Cruiser Patch' torsion bars. The following run will be finished in black and will be turned down to 29mm for those wishing to refresh their stock UZJ100.
Pulling a lot of information from these threads:
What I'd like to know is this: if I open the floor to pre-orders for some 27mm, 1210mm long HDJ100 w/ AHC 'Cruiser Patch' torsion bars, is there enough interest in some beefier TBs overseas that I should go ahead and get an order going? I'd also LOVE to confirm the diameters and lengths of the OE & aftermarket bars listed below:
For those curious how the difference in spring rate is determined, here's our calculations/equation*:
[(TB^4)/(25.4^4)]*100 = % stiffness of OEM AHC 1160mm 25.4mm bar
*metallurgy also determines spring rate. Given the unknowns about each manufacturer's material, these rates are merely estimates.
**some OE non-AHC 1160mm bars have been measured at differing diameters according to mud threads in the past.
Part No. (LH, RH) | Frame | Variant Details | Length | Diameter | % stiffness of OEM AHC bars* | Material | Notes |
LH: RH: | HDJ100 | w/ AHC | 1210mm | 25.5mm | 100% | - | Delisted |
LH: 48162-60010 RH: 48161-60010 | HDJ100 | 1210mm | - | - | - | ||
LH: 48162-60040 RH: 48161-60040 | UZJ100 | w/ AHC | 1160mm | 25.4mm | 100% | - | OE U.S. spec w/ AHC |
LH: 48162-60030 RH: 48161-60030 | UZJ100 | 1160mm | 28.87mm - 29mm** | ~167% - ~170% | - | OE U.S. spec | |
LH: 48162-60080 RH: 48161-60080 | FZJ100 | - | - | - | - | ||
LH: 48162-60100 RH: 48161-60100 | FZJ100 | w/ OE winch | - | - | - | - | |
Ironman4x4: TOY050-100LC | UZJ100 | 1160mm | 32.45mm | ~266% | "thick spring steel" | TOY050-LX470 (same part) | |
X-Sway (formerly Sway-A-Way): 1661 | UZJ100 | 1160mm | 32mm | ~252% | "Solid aircraft-grade steel, heat treated" | ||
X-Sway (formerly Sway-A-Way): 1660 | HDJ100 | 1210mm | 32mm | ~248% | "Solid 4340 alloy steel, heat treated" | ||
Old Man Emu (ARB): 303001 | UZJ100 | 1160mm | 30.4mm | ~205% | "premium grade spring steel" | ||
Old Man Emu (ARB) 303002 | HDJ100 | 1210mm | 32.8mm | ~274% | "premium grade spring steel" | ||
TJM: 657025 | UZJ100 | 1160mm | 32mm | ~252% | "premium grade spring steel" | ||
TJM: 657024 | HDJ100 | 1210mm | 32mm | ~248% | "premium grade spring steel" | ||
Dobinsons: TB59-1600 | UZJ100 | 1160mm | 32mm | ~252% | "heavy duty" | ||
Dobinsons: TB59-1610 | HDJ100 | 1210mm | 34mm | ~321% | "heavy duty" | ||
Cruiser Patch: 1661-CP27K | UZJ100 | w/ AHC | 1160mm | 27mm | ~128% | "Solid aircraft-grade steel" | |
Cruiser Patch: 1661-CP29.5K | UZJ100 | 1160mm | 29.5mm | ~182% | "Solid aircraft-grade steel" |
