100 Series Torsion Bar options (definitive table w/ part nos. and custom pre-order interest) (1 Viewer)
cruiserpatch
Supporting Vendor
Atlanta, Georgia
Website
www.cruiserpatch.com
Howdy!
It's come to my attention thanks to the feedback from some Diesel 100 owners that the AHC HDJ100 torsion bars have been delisted. I'd like to help get some options back on the market for those wishing to upgrade or restore their Diesel 100 Series Land Cruisers (and in the future, for all us petrol owners once our bars go DISCO).
We've just filled our first pre-order of 10x sets of 27mm, 1160mm long UZJ100 w/ AHC 'Cruiser Patch' torsion bars.
We're also currently shipping our first run of 29.5mm, 1160mm long UZJ100 'Cruiser Patch' torsion bars. The following run will be finished in black and will be turned down to 29mm for those wishing to refresh their stock UZJ100.
Pulling a lot of information from these threads:
What I'd like to know is this: if I open the floor to pre-orders for some 27mm, 1210mm long HDJ100 w/ AHC 'Cruiser Patch' torsion bars, is there enough interest in some beefier TBs overseas that I should go ahead and get an order going? I'd also LOVE to confirm the diameters and lengths of the OE & aftermarket bars listed below:
Part No. (LH, RH)FrameVariant DetailsLengthDiameter% stiffness of OEM AHC bars*MaterialNotes
LH: 48162-60020
RH: 48161-60020
HDJ100w/ AHC1210mm25.5mm100%-Delisted
LH: 48162-60010
RH: 48161-60010
HDJ1001210mm---
LH: 48162-60040
RH: 48161-60040
UZJ100w/ AHC1160mm25.4mm100%-OE U.S. spec w/ AHC
LH: 48162-60030
RH: 48161-60030
UZJ1001160mm28.87mm - 29mm**~167% - ~170%-OE U.S. spec
LH: 48162-60080
RH: 48161-60080
FZJ100----
LH: 48162-60100
RH: 48161-60100
FZJ100w/ OE winch----
Ironman4x4:
TOY050-100LC
UZJ1001160mm32.45mm~266%"thick spring steel"TOY050-LX470 (same part)
X-Sway (formerly Sway-A-Way): 1661UZJ1001160mm32mm~252%"Solid aircraft-grade steel, heat treated"
X-Sway (formerly Sway-A-Way): 1660HDJ1001210mm32mm~248%"Solid 4340 alloy steel, heat treated"
Old Man Emu (ARB):
303001
UZJ1001160mm30.4mm~205%"premium grade spring steel"
Old Man Emu (ARB)
303002
HDJ1001210mm32.8mm~274%"premium grade spring steel"
TJM:
657025
UZJ1001160mm32mm~252%"premium grade spring steel"
TJM:
657024
HDJ1001210mm32mm~248%"premium grade spring steel"
Dobinsons:
TB59-1600
UZJ1001160mm-"heavy duty"
Dobinsons:
TB59-1610
HDJ1001210mm-"heavy duty"
Cruiser Patch:
1661-CP27K
UZJ100w/ AHC1160mm27mm~128%"Solid aircraft-grade steel"
Cruiser Patch:
1661-CP29.5K
UZJ1001160mm29.5mm~182%"Solid aircraft-grade steel"
For those curious how the difference in spring rate is determined, here's our calculations/equation*:
[(TB^4)/(25.4^4)]*100 = % stiffness of OEM AHC 1160mm 25.4mm bar
*metallurgy also determines spring rate. Given the unknowns about each manufacturer's material, these rates are merely estimates.
**some OE non-AHC 1160mm bars have been measured at differing diameters according to mud threads in the past.
Hi Patch
Thanks for your efforts in organising the definitive torsion bar specification table and commissioning the build and supply of selected new bars. Torsion bars become a wearable item if you keep your vehicles on the road as long as us Landcruiser fan boys do. You can reindex a few times but eventually there is a degree of metal fatigue that must compromise the functionality of a torsion bar spring.
I enjoy the comfort of a working AHC system on my rig. I have reindexed the torsion bars, replaced the spheres once and fluid twice in the system in 600,000 plus kms so believe that is reasonable for the time and distance travelled. My torsion bars are getting tired and my belief is metal fatigue is compromising their function. I also have an ARB summit bar on the front which adds a little more weight to carry. What I have found recently is that there is no replacement torsion bar available for my diesel AHC equipped Landcruiser (25.5mm x 1210mm) from Toyota, Amayama or PartSouq. All the aftermarket torsion bars are 30-32mm which is too stiff for my AHC equipped rig.
Your special orders currently available for petrol AHC (27mm) and non AHC (30mm) are 1160mm so great for you petrol heads.
Us rolling coal types (diesels) need 1210mm long torsion bars in the following specs AHC (27mm) and non (AHC 30mm)
The 27mm spec for my AHC equipped diesel gives me a little more grunt over the OEM 25.5mm original to account for the extra weight of my ARB bar without going too stiff and compromising my AHC system.
Please receive my confirmation of interest in a set of 1210mm torsion bars at 27mm for my diesel 100 series equipped with a functioning AHC system.
Thank you for your support to the I8MUD community
Patch, as a new owner of a 1998 HDJ100L w/o AHC, you have my attention. I am dealing with the discontinued issue with other parts now. Working through it but I am interested.
I've copied this information into a page on our website so folks can view it sans-ads:
+1 here. I'll express my interest in a set of diesel AHC bars (1210mm x 27mm thick)
Have a 2001 HDJ100R with functioning AHC that is going to be kitted up for a trip from London to Cape Town next year. Planning to keep AHC for the comfort as we will probably see more washboard than hectic trails.
I like the idea of 27mm bars that could take slightly more weight with bumpers/winches installed and also possibly be cranked up a bit in the event of an AHC system failure to keep the car on the road until repairs can be carried out.
Hopefully shipping them to the UK doesn't double the price... 🤣
I'll be shipping these in pairs via long, tubular boxes. For example, our 1160mm petrol bars get shipped via a 4"x4"x48" box with a final weight of just under 14kg
The 1210mm will need a slightly larger box but the same principles apply- I'm sure you could go ahead and get some rates calculated to your address using that info^
I know I am needing to upgrade my stock LX torsion bars, but am struggling to understand the best choice options. I have deleted the AHC, Steel front bumper/ 12k winch w steel cable/ Dual battery setup / 863 rear springs / 35in tires. I have read so much contradictory information between the Ultimate torsion bar sticky to other posts and YT videos. If I under stand the science correctly, On the soft side of things (Current LX Setup & OEM LC TB) I will need to preload/index more to accommodate my Front end additions vs the thick Ironman will require significantly less preload and may feel softer on small bound/rebound bumps, but as the TB twist into full bound (compression) stroke the ride harshness increases significantly. Please correct me if I am wrong. Thx
The thicker the bar the less easily it will flex in low-speed compression situations but the less pre-load will need to be applied especially for heavier trucks.
For on-road behavior, thick bars (30mm+) sag less (i.e. minimal front end dive when braking). For off-road behavior, the thick bars reduce usable front end up-travel significantly (which on a 100 is already extremely limited).
I run small diameter bars to maximize my front end travel especially when getting my truck into flexy/bound up situations.
Had the opportunity to suggest to a local customer my new 29.5mm torsion bars for his 1998 Land Cruiser VX Limited.
He's deleting AHC (sad) and purchased the Ironman4x4 kit which included the 32mm bars (also made by X-Sway- where I source mine).
His 100 is fairly stock minus wheels and tires. His truck is actually lighter than a stock 100 since he does not have the third row seats.
32mm Ironman bars would have been overkill.
The side-by-side comparison was quite interesting.
Left to right: Ironman 32mm, Cruiser Patch 29.5mm, OEM 28.87mm (non-AHC petrol), OEM 25.4mm (AHC equipped petrol)
wow, i had no idea there were so many options. I am happy with my ironman TBars, but i did have take them on/off to re-index them about 2 times to get the setup just right. Annoying, but that's what happens when you start adding lots of weight ( bumper, winch, sliders, heavy rooftop , etc )
