Front Sway Bar Options
Nj
Hi all, I have a lifted LC100 on 33s. It has stock rear sway bar set up. But nothing in the front. On highway driving the roll is slightly jarring at speed, so I would like to install a front sway bar. I would like to find the best budget option, and was also wondering if anyone has a take on stock sway bar vs. aftermarket. I will install so labor and all those fees arnt in the cost. Thanks for reading! Cheers!
A stock used bar is definitely the best budget option, especially if you can find one locally. Whiteline is the only aftermarket bar I know of.
Consider longer sway bar links if you’re lifted.
Check to make sure your passenger side sway bar mount isn’t rusted off.
Do you know why you don’t have a sway bar up front? I only ask as I see you are in NJ, where things get rusty like here in Michigan. And when they get rusty, they can break, like the passenger side sway bar mount. Have you made sure yours is still there before buying a new sway bar? If you bought yours without the sway bar, that might be why it’s gone - because that’s my case. Easier to remove it than to justify welding a new bracket in. I don’t notice much difference with it being gone honestly.
I know for sure the rears are either 23mm (AHC) or 24mm (STD).
Can’t remember what the front is.
