100 Series Overheat
Shoot. That's not the water pump, is it? Looking at the front of the engine, bottom right on the serp belt. Who can tell me what it is before I find it?
And if there's coolant leaking from there, is it coming from the head gasket? GRRRRR
Picture of the area?
The lower right is AC compressor?
yeah, so there's a stead drip coming from the back of the AC Compressor. Unless i"m mistaken, the only way for coolant to be on top of the AC compressor is for the head to be pissing out the side. Any other theories?
N
ARRRRGGHHHh
Radiator in, fluid topped up, and now I'm leaking from what I believe to be the water pump. THat's the one on drivers side, driven by the serp belt, right?
So it seems like I'm going all in tonight. Gonna tear it all down and hope my dealer has my parts in the AM....
Anything else I should be looking at while I'm in there?
No, water pump cannot be seen. It is behind the timing belt cover and is driven by the cogged timing belt.
Your serpentine belt drives the fan clutch, A/C compressor, Alternator and Power Steering pump. BUT there are some small coolant hoses in the area you speak of. Look for leaks there...especially around the oil filter area.
Ok, there's a leak at the upper rad hose where it meets the engine, which COULD be carrying fluid down to the AC Compressor and explain that leak.
But now I"m dripping transmission fluid from a small hole in the center bottom of the transmission. What are the odds? On one side, it almost looks like a half drilled hole. On the other, it looks liek someone took a cutting torch to Aluminum. Is there meant to be a hole of any kind here? I'll get a pic up in a few
Get us a couple of pics. One close up...the other far enough away that we can tell the location (point at it).
Also give the year model of your 100 so we know which transmission we are dealing with
Thanks for putting up with my real time train of thought...
What if, when the old radiator exploded, a bunch of coolant got sucked into the transmission? Now the transmission is overfilled, with coolant, and the mix is what's coming out of what might be a weep hole where the trans meets the block. Reasonable?
It happened recently, so it's not milky yet, and both are red, so how would i tell?
Not likely. The lines from your transmission DO go to the bottom of the radiator to a separate cooler there before going to the externally mounted Trans cooler. But it would take a failure at that juncture to introduce trans fluid into the radiator and vice/versa (coolant in your trans fluid). IF in doubt, drain your trans fluid (just do a drain and fill, don't drop the pan) and inspect the fluid for capacity and appearance.
Both pictures taken looking front to back. There's clearly an access panel of sorts, and a built in weep hole. There's a lot of AT fluid coming out... Maybe a cup while I was idling to find the coolant leak.
Thats the weep hole at your inspection plate. And looks to be trans fluid. Possible front seal failure on transmission.
Is your radiator coolant also Toyota Red?
both red, but this feels like at fluid to me. how much pain am i looking at??
Its hard to determine until you get everything sorted.
I'd figure out the coolant system issues first. Then move on to the transmission. If the transmission is just a slow leak due to the seal, you can keep the system topped off until you have the engine cooling system straitened out. Have you pinpointed the source of the coolant leak? Clean off the coolant with water, top off the system, and start it up and look for leaks if nothing is obvious during the cleaning.
Look at all possible areas for leaks in your coolant system first (hoses and front and rear bypasses, heater Tees). Then suspect A/T fluid.
Year model of vehicle? A343F trans ?
fair enough. I know I have a leak on the upper hose. The clamp is not getting it done. Off to the store to get a better hose clamp. Thanks again for all the help.
Da Nada
Let us know what you find. Plenty of folks here willing to help and knowledgeable with respect to all common problems.
Don't panic. It looks like Toyota red coolant dripping from rear weep hole. You did used "red" didn't you! Since you had a leak at engine side of upper radiator hose. I'll bet it flooded the engine valley, by flowing over the top of water pump and front of engine. Then, drained out the back drains of valley under the stater. If ATF that will have a very nasty smell, coolant will be sweet.
Why you blew the radiator. Well the tops go bad and weaken then weep. Look back at picture @flintknapper posted where top of radiator is blown off. Then look at that cap and the hose in the reservoir. Notice anything. The cap is old and corroded and hose cruddy. If radiator cap becomes stuck, not releasing fluid at 15PSI to reservoir, pressure keeps builds within the coolant system. Something must give. That's weakest point.
I've replace 5 radiators in last year. Three the tops where crumbling. Non blew. Why? Cap were working.
When I replace Radiator I also swap all form to new one. If using OEM they come with new foam, but for the saving I'll swap and glue. I also replace cap, thermostat and both upper and lower hoses.
But if for some reason I've reused any hose. I always place back in same spot and always put factory clamp in same spot. The clamps leave marks on the old hose making it easy.
Did you damage heads or heads gaskets.
Not likely form Just from this. It generally longer term where the coolant was not detected leaking and drop below water sending unit. Temp gauge reads cool when this happens, because sensor is reading air rather than fluid temp. Then driver just keeps driving thinking all is okay, and really heating it up. I've seen knock sensor, cam sensor and intake manifold melt (VVT engine) when this happen. Hose in engine compartment turn brown. Oil turn to milkshake as coolant mixes in.. (see Unicorn)
Whew. What a night. Man, I hope you're right on the leak at the inspection hole at the flywheel. Makes sense.
I got a real hose clamp on the leaking hose, and now everything seems mostly ok. I still get drips from that weep hole, but maybe it's just the coolant? It seems oily to me, but it could have picked some up on its way back there. Either way, I'm going to roll with it and see what happens. I'll keep an eye on AT, Oil, and Coolant levels (and milkshakyness) for a while. Maybe I got lucky and scared myself over nothing. Was pretty s***ty to be under the truck and then get rained on from multiple places...
Earlier question: this is a 2000 which I believe does have the A343F. I have a dipstick.
Up next is the water pump and timing belt. I'm hoping to do this at a more leisurely pace without my wife wondering when she'll get her rig back!
