Should be D60 thread but..
HI^C
You made some points that I would like to discuss in another thread but do not want to colud the issue.
1. You do not like the provision to mount the DL to the TR using the stock shock hole, why is that?
2. You state that a D60 is the best axle suited for a Hy steer conversion. What difference do 60's have over Toyota axles? Considering that Cruiser axles are basically hy steer (converted to low steer) stock to begin with.
3. The bearing conversion on stock knuckles is VERU expensive and requires a completly new custom welded knuckle.
4. why do you think that a ram assist does little to add to the strength of a stock tie rod when it is mounted to it?
5. why do you think that an Atlas has questionable strength?? I understand them to be some of the strongest tcases out there.
6. I cannot see how a 14.50 tire on a 6"bs 10" wide rim would not leave the hubs in danger. If running drive slugs it would be different but..
HI^C
