Finally swapped out my tired 1F for the younger 2F sitting on the floor.
It took 3 days, which was 1 day tooooo long.
The only big issue is an exhaust leak...of the exhaust studs appeared to slip as I was torquing the intake/exhaust (slipped at 25lbs, all others are set to 30lbs)
I called my favorite Toyota parts guy (John Hocker - Sierra Toyota), and ordered a bunch of studs.
I'm hopping that the new studs (switching from bolts to studs) will take care of the leak.
Other issue maybe a stuck thermostat (stuck closed), upper hose appear to have any flow...
Here are some pics for your enjoyment.
Simply remove motor for increased lift
Busted one of my radiator support studs, so I called one of my buddies that doesn't live in Stockton.
My 1st TIG work, Thanks Doug
Install new 465 pilot bearing, thanks treeroot for part#
almost there
now where did I put that bib?
TRUST ME, next time I'll take one of the many cruiser-heads offers to help...One-Man-Job = No Fun
Does anyone want to trade something for a 1977 clutch-fan shroud?
55 fan will not mount onto 2F wp, and 1F shroud does not fit 77 clutch-fan.
Let me know If your interested in any of the following (left over from swap):
55 plastic cooling fan/spacer
2F alternator/bracket
1F water pump recently installed
2F valve cover
1F fan shroud
4spd Bell-housing
4spd flywheel
2F intake/exhaust
2F smog pump w/o bracket
2F dizzy
2F side-cover
old cranky 1F
77 2F starter
(air plumbing along the top of head are a few ends short...twisted off)
almost there
2F valve cover
1F fan shroud
4spd Bell-housing
4spd flywheel
2F intake/exhaust
2F dizzy
2F side-cover
old cranky 1F
77 2F starter
