- Thread starter
- #101
Wow yeah, yours looked a lot better than mine before your C Channel replacement. Its for sure on the "to do". But I think my big next push will be when the suspension parts are all gathered and I can try to smash both out in the same time as per BCSteel's recommendation.Not a fun job, more a right of passage, like rebuilding the front knuckles.
Thank you! I will take as many suggestions as I can from those more experienced. Haven't bothered with the fuel items yet but it is no doubt on the "to do". I likely have an airleak somewhere as the 3B is hard to start the longer it sits stationary. My truck currently leans a good 1" to the drivers side rear, pretty sure I have a broken leave somewhere.These are just suggestions. Nice job on your truck.
(edit: Maybe not an air leak, I've noticed that since the weather has been warmer, and i glow the system 2-3 times before start up and pull the hand throttle out a smidge, she fires up WAY easier when its not below 0 degrees C.)
My big inner debate right now is for the suspension.
Do I go with a lift and 33"s? A lift and 31"s? Do I go with a more stock suspension set up and 31"s?
Its all kind of up in the air, but since I'm not planning on doing any "serious" off-roading, just forest service roads and backcountry camping, ill go with a less aggressive set up...
