r2m
Richard
I can't take credit for the procedure, it was from another post, but I thought it wouldn't hurt to have a another post or so for it to aid in search's when one needs it.following r2m's procedure
I did that last weekend. Kind of a PITA cycling the switch with one hand and the lock with the other but doable..Manually lock and unlock the sequence to program the buttons
Great deal on getting TWO masters for AND programed for $120 clams!
Can u elaborate or describe in detail by what you mean to "Manually Lock and Unlock" Please.
I did this and it Worked!!! Thank you guys so Much!!!Look by your inner door handle. Use the manual lock/unlock to perform the lock/unlock sequence.
This worked like a charm. Manually cycling just the driver door works perfectly.I have a 2000 LC with weak actuators and I was able to successfully program a new key fob just now by manually locking/unlocking the drivers door only (rather than pressing the master button that controls all the locks per the instructions).
I must have tried 30x using the power door lock/unlock sequence and was about to give up but then found this thread and tried the manual lock/unlock and it worked the first time! Now I've got a spare fully functioning key with the fob buttons. Thanks!!
Steps: Driver door open, unlocked. All other doors closed. Key in ignition and back out (do not turn). Manually cycle driver door lock five times. Close door. Open door. Manually cycle driver door lock five times. Key in, turn to ignition on (do not start), back out. Lock cycles, indicating programming mode. Press lock/unlock for one second. Lock for two seconds. Bingo.
Now the issue I am having:
Vehicle goes into programming mode. Press lock/unlock for one second + lock for two seconds. Locks cycle twice, suggesting the new-to-me key fob has been mated. Close driver door. Try unlocking doors from the fob. Nada. Try locking doors from fob. Nada. Exit vehicle. Try unlock, lock, and panic. Nada.
Brand new battery in an OEM key fob. Key is already cut and programmed to vehicle. Fob in a YotaMD case.
Ideas?
This worked for meManually lock and unlock the sequence to program the buttons
Thanks @BnvS. Does the ECU limit the number of fobs or is it the master key? I always thought the constraint was 5 masters. Was able to program the key as a master, just not the lock/unlock function.Do you have techstream to verify how many keys are programmed into your ecu?
To me it looks like you may have maxed out your keys. But that's just a guess and not from experience.
Local Toyota dealer?They told me it was an ECU screw up on the 1998 only and they would replace it for free, but I have to pay the cost of labor and I also had to buy 2 new keys. That was like $600 I think. I told them that the Toyota certified mechanics should know about this, and the service writer should have a "red flag" in his system saying that they cannot re-program a 98 ECU. But, they didn't know about this before they erased it, so I eventually had to raise my voice which took 2 weeks. If they quote $47 and then leave me with a car that doesn't run, then I think its their responsibility to fix. Crazy.
This thread was helpful to me. I just programmed two new keys today. $44 for Amazon for two blanks, $1 for Ace to cut them, instructions here. Done. Thanks to the OP and everyone that had input.I can't take credit for the procedure, it was from another post, but I thought it wouldn't hurt to have a another post or so for it to aid in search's when one needs it.
Yes, it was. They have changed employees and things have been better there since though. It was just poor communication on their part. I walked in there after 2 weeks of this nonsense, with my 1 year old daughter in a baby backpack. I stormed into the service bay yelling for the manager. Must have been hilarious to see me pissed off with a baby on my backLocal Toyota dealer?
I only allow them to change my oil. I'll stop by sometime and tell you a story about their Master mechanic.Yes, it was. They have changed employees and things have been better there since though. It was just poor communication on their part. I walked in there after 2 weeks of this nonsense, with my 1 year old daughter in a baby backpack. I stormed into the service bay yelling for the manager. Must have been hilarious to see me pissed off with a baby on my back
where is this again???Look by your inner door handle. Use the manual lock/unlock to perform the lock/unlock sequence.
