Inner axle seal? (2 Viewers)
Breather is a good call.
If it's not clogged, use only Toyota inner seals.
I've used ALL THE OTHER OPTIONS, nothing compares to Toyota stuff.
Indeed - even the marlin crawler ones are s*** compared to the genuine Toyota ones. Sad but true.
Checked the axle seals that came with the sumo gear kit from cruiser outfitters (purchased last year), and they are a NOK BH4371E
Not to jump in your thread here, but with factory axles and all, anyone have thoughts on feeling like I should grab some OEM seals?
NOK is the OEM seal manufacturer fwiw
There is also the possibility that the spring got kicked-off the inner seal lip during assembly. I've seen that happen.
