I just did mine today. I made a plate to hold the harmonic balancer out if a 1/2" sheet of fiberglass. Worked great.
Just happened to have a piece of 1/2" thick FRP hand lay up flat stock made from non directional E glass laying around?I just did mine today. I made a plate to hold the harmonic balancer out if a 1/2" sheet of fiberglass. Worked great.
I cut a square hole and used a 3/4 inch breaker bar against the frameView attachment 2894185
That is a great way of securing the crankshaft!!!! What did you use to hold the fiberglass in place in the square hole?
I'm using Mobile-One also. I got a little oil coming from this area. I think it's the oil pump seal. Have you replaced your oil pump seal yet?There is at least one other that I know of. I've been running M1 0-40 in mine for 11 years.
Alright guys, I got the video footage all edited and published on my Youtube channel. See the video on how to do these oil leak repairs here:
I really leveraged the thread here and most of the "tricks" folks have come up with here, I tested and used in the video. So hats off to you guys and I hope the video helps those folks who are visual learners! haha
Take care, Clay
i don't think that gaskets/o-ring swellsChanged out my kids 96 land cruiser main seal and oil pump o-ring. Went with out a hitch so to speak had to go get a starp wrench to hold the water pump pully to tighten the fan back on but other than all went well. Well low and behold go out this morning and there is some fresh oil on the driveway!!! I say in earlier post that some time it takes a few days for the o-ring to swell up? Anyone had this issue? Anyone monitor this post any more LOL. Thanks in advance
i did the job last week, and my steering stabilizer is still shedding the oil i leaked on/into it for 2 years.Changed out my kids 96 land cruiser main seal and oil pump o-ring. Went with out a hitch so to speak had to go get a starp wrench to hold the water pump pully to tighten the fan back on but other than all went well. Well low and behold go out this morning and there is some fresh oil on the driveway!!! I say in earlier post that some time it takes a few days for the o-ring to swell up? Anyone had this issue? Anyone monitor this post any more LOL. Thanks in advance
Yeah I was thinking it might be something like that. The front of his engine was oil leak mess. I cleaned for good hour. Ill just keep a eye on it. I dont feel like I could have done anything differenti did the job last week, and my steering stabilizer is still shedding the oil i leaked on/into it for 2 years.
I did the valve cover, the dizzy O-Ring at the same time in order to take care of the engine oil leaks from the top down.Changed out my kids 96 land cruiser main seal and oil pump o-ring. Went with out a hitch so to speak had to go get a starp wrench to hold the water pump pully to tighten the fan back on but other than all went well. Well low and behold go out this morning and there is some fresh oil on the driveway!!! I say in earlier post that some time it takes a few days for the o-ring to swell up? Anyone had this issue? Anyone monitor this post any more LOL. Thanks in advance
Funny you could mention it - all sitting on the shelf waiting to go on if I can get the screws outWe have all be there, I would normally suggest Joey Wits End @NLXTACY jis bits but your pretty well done. I'll get these beds regardless to prevent future stripping of threads and heads down the road.
I did all this a few years ago and in hind sight I wish I would have pulled the head, oil pans, timing cover, radiator and just baselines doing it all at once.
I learned the hard way in and out in and out and got bit on a head gasket and had to do it all again anyway.
Anyway I don't know the history of your truck or the previous owner but yes pulling the radiator will give you more room, if you're not going to baseline the whole unit you can gently drill out or use easy outs with a little propane heat, careful now go slow.
Not knowing your history and again sharing my experience I wish I would have just done a valve/head gasket job timing chain the whole bit out the gate.
