love2fly
Flying the Mountains of the NW
I finally got around to having an all wheel alignment completed on my 1982 FJ45.
The gent that did the alignment check (only a check) told me that all seems good as far as he can see, but could use a bit of tweaking in some areas?
I was mainly interested in the Castor of the truck to know if it needed to be shimmed due to re-arcing of the leaf springs but to be honest I am not a well verse alignment person and reading the data sheet from the visit , I am at bit of a loss in knowing what some of it means as in what I need to do and how from here.
I know he said that the rear thrust angle was out as shown so I not sure if I need to loose up the rear axle and try to move it left or right to get to track with the front or check the spring hangars or frame for being bent?
I know some of you guys out there know more about this stuff than I so I am asking if someone can read the results and help me out from what you see.
Any information is more that welcome.
Thanks
All stock:
16" wheels with 32" tires (new)
Springs (front and rear) re-arced to near stock level
Thanks
All stock:
