78fj40mg
TLCA #23510
Ohhhh man.
...via IH8MUD app
Too bad you are not close to PNW I'd love to help you install your tranny.
Ohhhh man.
...via IH8MUD app
I am sure by now everyting has been done or tried.
what is the point of the community if all it is is search old posts.
maybe someone has a new spin, mother necessity creates some innovative solutions.
Rent a transmission jack. It's the only way to be sure.
Presumably you used a clutch alignment tool as well. Without that you could also be doomed.
Also.... Is the throwing clutch bearing (new) greased in any way? The bearing “mount” thing with the clips that holds clutch fork had lots of grease in the channel inside of it. Not sure what that’s from although I would think you’d want where fork touches this housing at two points to be lubbed. Can you even get to that when all reassembled for regular maintenance?Hi All- over last couple w-ends been working at clutch and tranny/t-case seal/gasket replacement. Pulled everything with two floor jacks and truck jacked up, but on the ground (no lift). After reading this wondering if couple of questions: Better to install tranny first then mount T-case? Don’t have another set of hands or tranny jack. If I did rent one, are the low enough to use under jacked vehicle vs. one on a lift?
Thanks to all!
Thanks Much- 33s with Fox lift ~3”. Even if I need to jack it up some, not an issue. Just most of the ones I’ve seen have a long/tall adjustable pedestal....No; you will be far better off to assemble the t-case onto the transmission and install them both as one unit.
That depends on how much lift your truck has, how big the tires are, and the transmission jack I guess. With 33" tires and a 3" lift, and a Northern Tool transmission jack, mine fit under the truck sitting on the ground, but YMMV.
Ok Thx- I know you want to keep grease away from friction items, so will still need to look at why there’s grease in throw-out bearing housing (if that’s what it’s called with the fork clips)....?No. You wouldn't want any grease to get on the clutch plates.
I don't have my factory service manual handy to look, but I don't remember putting any grease or lube on mine last time I did it. The clutch fork doesn't need any regular maintenance that I know of, as long as the hydraulic system is in good shape and the pedal and master cylinder clevis are adjusted.
So, I just finished reinstalling the H42 trans/transfer back into my 77 FJ40 by myself with a chain winch pulling the assembly up with a chain wrapped around it and a floor jack with a 2X4 supporting it from the bottom. I'm not a small guy, but it definitely put up a good fight! I didn't search before, so once i had it lined up and somewhat close, I made the mistake of using the four mounting bolts to close the gap to the bell housing. From what I'm reading, I should have avoided that. Any way to tell if I did any harm? Should I pull it back out and check anything or send it? I put it in gear and 4wd and spun the flywheel by hand and the front flange turned, so I think it's ok, but want to make sure if there's any way to do that.
Thanks for all the posts. Old thread. So thankful for it though.Pull the e-brake off if it's still on. Loosen, but don't disconnect the rear motor mounts. Pull the front motor mounts and jack up the front of the engine as far as it will go. It will hit on the firewall eventually. This should give you enough clearance at the cross member. 7 hours is tough. Here's a moral support pic:
